Author Topic: Dzus fasteners  (Read 1968 times)
Dzus fasteners
« on: February 14, 2011, 11:54:17 AM »
Was wondering if anyone on here (possibly one of our aviation inclined members) knows if dzus fasteners are robust enough to use in mounting some Krauser bag frames?
I have seen them used in a lot of racing and aircraft applications but not necessarily what I would consider a load bearing function. The ones I have and was considering using are very stout, approx 1/2" in diameter in stainless.
My r65 is pretty well streamlined and the rear subframe has been modified enough that most of the normal mounting points are no longer there. I don't want to keep the hard bag frames mounted but there are times it would be nice to use the bags. I don't want to be bolting and unbolting ever time I want to use them and think I would use them more if I could "quick release" them.
I was planning on welding on some tabs in strategic places and using the dzus fasteners to accomplish the quick release of the frames. Any comments or suggestions?
Offline donbmw
Re: Dzus fasteners
« Reply #1 on: February 14, 2011, 12:58:56 PM »
I would not use Dzus fasteners where they will have to support any weight. I have seen some break under normal use.
Don
Re: Dzus fasteners
« Reply #2 on: February 14, 2011, 01:53:53 PM »
Dzus fasteners are fine for cowlings, inspection panels, etc on aircraft but I would not trust them to secure saddlebags. The bags weight and constant "jiggling" could detach the bag without your knowledge.
My experience with Dzus is that they are a godsend for body panels; ease of removal is paramount when time counts.
There is an entire voodoo technique for selecting the correct fastener :D
« Last Edit: February 14, 2011, 01:54:44 PM by montmil »
Re: Dzus fasteners
« Reply #3 on: February 14, 2011, 04:14:27 PM »
Thanks guys. That is what I was looking for as my knowledge of them amounts to removing a few engine cowls a lifetime ago. Back to the planning stage.
Re: Dzus fasteners
« Reply #4 on: February 14, 2011, 04:24:57 PM »
Perhaps it's time to add a second bike (R65?) to the stable?  8-)
Re: Dzus fasteners
« Reply #5 on: February 14, 2011, 09:23:39 PM »
I already have an 82 LS, am 84 LS and a 90 K75S along with 4 push bikes (bicycles). I am running out of room! It's either thin the herd of build a bigger garage.
Re: Dzus fasteners
« Reply #6 on: February 14, 2011, 09:55:24 PM »
The other LS doesn't have bags, I take it.
But surely the K75S does?  That is one of my favorite bikes!
