Author Topic: Fuel Tank Mounting  (Read 3858 times)
Ben_Carufel
Fuel Tank Mounting
« on: January 20, 2011, 08:12:27 PM »
At some point one of the previous owners of my 1979 R65 buggered with the fuel tank and didn't get it mounted on tightly...that, or the rubber pads it rests on have "compressed" and the u-bolt that holds the back of the tank has loosened as a result.
In looking at the ETK, it seems like there's 3 "isolators" for the tank. One is the long, somewhat cylindrical rubber piece at the front (#4 in the below diagram). It also appears that there are two near the back of the tank, close to the u-bolt. Are these #2 and #3 in the diagram?
I'm planning to order the parts (and a petcock rebuild kit or new petcock), pull the tank, polish and clearcoat it using two part clearcoat, install new emblems and the new/rebuilt petcock, install a new overflow drain hose, and reinstall the tank using the new mounting rubbers.
Thanks for your help in nailing the parts down!
Re: Fuel Tank Mounting
« Reply #1 on: January 20, 2011, 08:26:45 PM »
Yes - you have identified all three cushions.
The front one is no problem, but I've found the glue can fail on one or both of the rear pads.  I lost one when I didn't realize it had fallen off when I removed the tank, once, a long time ago.
I doubt compression will be a problem with these OEM pieces.
Also, make sure the rubber on the u-strap (bail) is in good shape.  Being rubber, it can only deteriorate, although mine is doing just fine.
Ben_Carufel
« Reply #2 on: January 20, 2011, 08:28:05 PM »
Damn, I didn't realize that bail was supposed to be covered with a piece of rubber. I didn't find the bail or the rubber piece in ETK. Any idea if they're in there, Rob? Is the rubber piece just fuel hose slid over the bail?
« Last Edit: January 20, 2011, 08:28:36 PM by Ben_Carufel »
« Reply #3 on: January 20, 2011, 08:29:33 PM »
Damn, I didn't realize that bail was supposed to be rubber coated. I didn't find the bail or the rubber piece in ETK. Any idea if they're in there, Rob?
#13.  They call it a "bracket".   ::)
It is not "rubber coated", it is a thick piece of rubber with a hole in the center, which the bail goes through.
When you do the final install of the tank, that rubber just rolls underneath the main frame tube.
It looks like the bail & rubber come as once piece.
Find a really trashed tank, and you can probably pick it up for a song.
« Last Edit: January 20, 2011, 08:32:35 PM by Rob_Valdez_79_R65 »
« Reply #4 on: January 20, 2011, 08:35:06 PM »
If the rubber on the bail is missing, the whole thing will feel wrong.
Offline Bill Conquest
« Reply #5 on: January 20, 2011, 10:07:05 PM »
I'm having the same problem on my '79..i'll order the two back parts, same as Ben, but the rubber is also missing on the bail & there's nothing available locally..any other solutions?
thanks, bill conquest
79 r65/75 r60/76r75/76r100
« Reply #6 on: January 20, 2011, 10:43:52 PM »
Take the bail to the hardware store to see what they have.  When I get home I can measure the outside diameter for you, if you want.
Ben_Carufel
« Reply #7 on: January 20, 2011, 11:02:35 PM »
Hey, Bill, I'll be in Kauai next week. There's a new resort near poipu beach that I'm photographing.
« Reply #8 on: January 21, 2011, 12:30:00 AM »
Wow - you get paid to go to Hawaii and take pictures?  I'm jealous!  :)
Ben_Carufel
« Reply #9 on: January 21, 2011, 03:43:26 PM »
Yep, that's the "glamorous" description of the job!
« Reply #10 on: January 21, 2011, 04:39:22 PM »
Well - I am back at work, again, and I forgot to go out to the garage last night or this morning.  Perhaps it was the very very cold temps that made me forget.
But it will be the weekend soon!  I promise not to disappoint! :)
« Reply #11 on: January 21, 2011, 09:25:52 PM »
Thanks alot, Rob..i'm hoping to improvise something. Hey Ben - give me a call if you get time.. maybe we can get together for a beer!
bill conquest 808-635 - 2975
chewy4x4
« Reply #12 on: January 21, 2011, 09:39:38 PM »
Hey would 3/4 of a tube of pipe insulation replace the #2 and #3 supports? I was thinking just zip tie it to the tube.
« Reply #13 on: January 21, 2011, 10:15:12 PM »
Yeah - I've seen all kinds of cheesy improvisation supporting the tank.  Nothing beats OEM, as far as I am concerned - especially as they are still easily available.  Did you know you can special order ANY BMW part at your local BMW auto dealer?
I'll shut up, now.  :-X
Offline Julio A.
« Reply #14 on: January 22, 2011, 04:52:51 AM »
I don't have those side mounted rubber thingys on my tank.
I did not even know they were supposed to have those.  ;D
No wonder they are wobbly.
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
