Author Topic: Fuel Tank Mounting  (Read 3848 times)
Re: Fuel Tank Mounting
« Reply #15 on: January 22, 2011, 04:56:52 PM »
I don't have those side mounted rubber thingys on my tank.
I did not even know they were supposed to have those.  ;D
No wonder they are wobbly.
Without some kind of padding, it is possible for the frame, or something else to rub against the tank, and possibly wear a hole through it!
Offline Julio A.
« Reply #16 on: January 22, 2011, 07:41:37 PM »
Where do these mounts fit? on the frame or on the tank itself?
« Last Edit: January 22, 2011, 07:41:54 PM by JAlarcon »
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
« Reply #17 on: January 22, 2011, 07:44:19 PM »
They are glued to the tank itself .
If you take the tank off, you can probably still see the glue where they were originally installed .
I think they were installed at the aft end of the tank, they sit on the frame tubes .
« Reply #18 on: January 22, 2011, 10:49:04 PM »
20mm wide, 15mm thick.
I wonder why so many bikes have them missing?
« Last Edit: January 22, 2011, 10:49:42 PM by Rob_Valdez_79_R65 »
Teo
« Reply #19 on: January 23, 2011, 01:08:06 PM »
I put a 2"-3" piced fuel line on the bale.  Works fine.
chewy4x4
« Reply #20 on: January 24, 2011, 01:37:55 PM »
Yeah Yeah Rob. I agree. What kind of adhesive would you use to put them back on?
« Reply #21 on: January 24, 2011, 02:14:43 PM »
I haven't found it, yet.  My left one is still in place from the factory.  The right one I have to keep track of whenever I remove the tank.
« Reply #22 on: January 24, 2011, 02:35:58 PM »
Stuck mine back on with ordinary impact adhesive .. did the job.
« Reply #23 on: January 25, 2011, 09:48:25 AM »
An automotive exterior trim adhesive should work, usually found at the chain type auto parts store .
