Author Topic: RMS leak...  (Read 2918 times)
VaSteve
RMS leak...
« on: December 31, 2010, 06:59:01 PM »
...ya think?    ;D
I've known it was leaking for a while.  What a mess.... This project is a full down strip, clean and paint, so now is the time to do it.
Also have a nifty leak on the pushrod seal.    The leaks aren't so bad, but all the crap that sticks in the oil makes it all the worse.
« Last Edit: January 02, 2011, 01:32:40 AM by Rob_Valdez_79_R65 »
Re: RMS leak...
« Reply #1 on: December 31, 2010, 08:26:28 PM »
Well - maybe a little!
Don't forget the large o-ring on the inside of the flywheel/starter ring-holder.
(#6, here - http://www.realoem.com/bmw/showparts.do?model=0363&mospid=51897&btnr=11_1716&hg=11&fg=25 )
And I read of one fellow replacing his RMS twice before discovering his oil pump cover was cracked!  So give that a good look-over.  And I have a spare if you happen to need one.
I really like your idea of unplugging the wiring harness before removing the transmission!  Then you can wrestle with the neutral switch contacts on YOUR terms! :)
« Last Edit: December 31, 2010, 08:29:20 PM by Rob_Valdez_79_R65 »
VaSteve
Re: RMS leak...
« Reply #2 on: January 01, 2011, 04:49:39 PM »
It just turned out that way....I couldn't tell the difference between the wires, they were so dirty.   :)
VaSteve
Re: RMS leak...
« Reply #3 on: January 01, 2011, 04:57:14 PM »
Rob, I'm confused....I haven't taken the flyhweel off yet since I didn't have the right bolts to put it back on.   I also (apparently) don't have the right RMS either.  (Shop sent me the driveshaft seal).
The red ring you show in the photo looks like the O-ring for the oil pump cover in this photo http://www.northwoodsairheads.com/maintenance-parts.html  (half way down).
What does the R65 look like with the flywheel removed?  What number is the RMS in the realoem link?  I couldn't figure it out.
Thanks!!
Re: RMS leak...
« Reply #4 on: January 01, 2011, 05:33:58 PM »
« Last Edit: January 01, 2011, 05:35:26 PM by Bob_Roller »
Re: RMS leak...
« Reply #5 on: January 02, 2011, 01:23:27 AM »
Thanks!!
Steve, the o-ring for the oil pump cover is thinner in diameter than the one for the flywheel.
I found out the hard way when I tried fitting the larger one in the oil pump cover.  I was confused, to say the least.
This is what the rear of the crankshaft looks like with the flywheel removed:
Go here for more pictures: http://www.pbase.com/tomfarr/flywheel_change
VaSteve
Re: RMS leak...
« Reply #6 on: January 02, 2011, 10:27:56 AM »
Bob and Rob, the photos and links are very helpful.   Thanks!
Offline Mike V
  • 78 R100/7 , 81 R65
Re: RMS leak...
« Reply #7 on: January 02, 2011, 11:10:50 AM »
Steve,
Here's a few more links of pictures of the RMS procedure.  Much easier with motor removed but hopefully this will give you an idea of what to expect. Did I miss what year your R65 is?  The following are of my 81 R65, hope they help.
RMS;
http://s428.photobucket.com/albums/qq8/gruntyman66/81%20R650%20Restoration/Rear%20Main%20Seal/#!cpZZ1QQtppZZ16
Oil Pump;
http://s428.photobucket.com/albums/qq8/gruntyman66/81%20R650%20Restoration/Oil%20Pump/
Clutch Pack;
http://s428.photobucket.com/albums/qq8/gruntyman66/81%20R650%20Restoration/Clutch%20Pack/
-Mike V.
Mike V. / San Diego
'78 R100/7 (original owner)
'81 R65 (fully restored)
VaSteve
Re: RMS leak...
« Reply #8 on: January 02, 2011, 02:46:40 PM »
Wow Mike,  that's seriously clean in there!  Mine's an '80, so the clutch photos aren't the same.  No worries though.  What did you use for all the cleaning?
My whole bike is *completely* apart.   I'm sort of restoring it as well, paint, etc.   I was trying to get the driveshaft out of the swing arm.   Clymer's shows a nut to take of the collar that meets the final drive, but that's clearly a different bike.  How's that done on an R65.
It's amazing how much you learn about something when you take it apart.  I'm having a ball!
Re: RMS leak...
« Reply #9 on: January 02, 2011, 03:19:01 PM »
To get the drive shaft out of the housing, you need a tool that looks like a McPherson strut compressor tool .
The final drive end of the drive shaft is where it comes apart , you need to compress the drive shaft, then you can see the wire circlip on a groove on the shaft itself, it keeps the bell/gear part of drive shaft from coming off .
http://www.realoem.com/bmw/showparts.do?model=0364&mospid=51897&btnr=26_0112&hg=26&fg=05
You need to compress item #7 the spring, to get access to the clip .
« Last Edit: January 02, 2011, 03:24:54 PM by Bob_Roller »
Offline Mike V
Re: RMS leak...
« Reply #10 on: January 02, 2011, 04:14:05 PM »
Lots of Brake Cleaner, Simple Green (50-50 mix), grout brushes, scotch brite pads and more labor than I want to admit.  I agree - it's a kick to get inside these bikes while the tricks, lessons and education never stop. This forum will end up being one of your most valuable tools.  There's a gang of knowledge, experience and sharing of passion here.  Good friendly folks always willing to help and guide you on the right path.  Good luck with your project!
-Mike V. / San Diego
Mike V. / San Diego
Re: RMS leak...
« Reply #11 on: January 02, 2011, 05:21:23 PM »
Great photo documentation of your work, Mike. Very helpful. [smiley=thumbup.gif]
VaSteve
Re: RMS leak...
« Reply #12 on: January 19, 2011, 08:58:42 PM »
Finally got to the part where I take the flywheel off.  What a mess.  This is after I dumped a bunch of foaming engine cleaner on this and hosed it off.
Uploaded with ImageShack.us
Nice and tidy.
Anyone know what this block off under the breather hose is for?
Re: RMS leak...
« Reply #13 on: January 19, 2011, 11:19:37 PM »
Crankcase ventilation.
Re: RMS leak...
« Reply #14 on: January 20, 2011, 06:59:30 AM »
Yes it's for crankcase ventilation as msbuck says and it is or should be a reed valve. The strip of metal secured by the screw is just a stop to limit the travel of the thin reed underneath.
