Author Topic: My baby let me down..  (Read 3099 times)
wiemer
« on: May 14, 2007, 03:10:26 PM »
....in a serious way.
She died yesterday on the German Highway, where one is allowed to go 130 MPH.
But my R 65 could not stand 6.000 RPM over 10 minutes; the left bigend went out.
And she behaved so well lately...gradually used more of the power....
It took me 2.5 hours to crawl back to home, at a pace of 20 miles.
I still have a bare engine in the basement though.
And I have the " opportunity" to open the gearbox as well, because it makes too much dust of iron in the oil.
Or I drop this one in the basement too, and buy another one.
This asks for a nice spreadsheet calculation.
Before summer holidays no more BMW with nice RS fairing.
Also because my wife wants to redo the wooden floor, and paint the interior.
Then she doesnt like it when I am tinkering in the shed....
So a spanner in one hand, and a paint brush in the other.
Wiemer.
Re: My baby let me down..
« Reply #1 on: May 14, 2007, 10:42:57 PM »
 BUMMER!! Sorry to hear your bad news...
May your calculations tell you the answer you want.
« Reply #2 on: May 15, 2007, 12:26:44 AM »
Yikes.     :(    Sorry to hear of your misfortune.  Good luck getting it running again!
wiemer
« Reply #3 on: May 15, 2007, 01:29:21 AM »
Well the calculation is simple.
If I sell the dead R 65, I have lost some 1.000 E.
Yes yes, sunk costs..... :o :o
And, if I can fit the 1979 stuff on the 1986 bare engine only with crank+camshaft, it is only time I need, no money involved.
...what am I waiting for????
so..lets say..Thursday (holiday) the old engine + trans out, etc.
It is all supposed to be fun, so I will have fun!
wiemer.
trolle
« Reply #4 on: May 15, 2007, 03:13:53 AM »
Schade! Aber eine neue Motor zu bauen macht doch spass. Hab Glück.   [smiley=thumbsup.gif]
Sorry my German is very rusty.
greetings from a sunny and windy north
trolle
wiemer
« Reply #5 on: May 15, 2007, 03:38:34 PM »
Hi Trolle,
About your bike:
How are the heads now? The last thing I know is that the new exhaust valves
were digging themselves in the heads. Okay now?
Wiemer
trolle
« Reply #6 on: May 15, 2007, 03:43:31 PM »
They were redone last year with new exhaust seats and valves and after securing the butterfly of the right carb the engine is running better than ever - steady idling at 750 rpm and running up to 7500 rpm with no trouble at all. It is really a joy to ride her now.
Hope you will manage to assemble a working engine from the two you have.
greetings from a windy and cold north
trolle
« Reply #7 on: May 18, 2007, 09:21:46 PM »
wiemer,
Are you aware that the clutch from the '79 may not go on the crankshaft of the '86.
And if you have a clutch for the '86, I am real sure that it will not hook up to the '79 transmission without some trouble.
Those are pretty different animals.
Just now "stripped" is the '86 engine?
No ignition/charging system, no starter - when did it last run?
Sorry for your troubles...
Chris_in_BC
« Reply #8 on: May 19, 2007, 04:04:45 AM »
Rob,
 I think if you keep the 79 clutch and the 79 flywheel together and 79 gearbox  or 86 clutch components and 86 flywheel and 86 gearbox, you should be OK
The short blocks should be swappable, no?
Chris
wiemer
« Reply #9 on: May 21, 2007, 04:33:29 PM »
hi,
(ight arm in mitella because of a dull but severe pain) the bare engine is crank (obvious) cam, distr. full stop.
i bougt it for cyls ans heads,
which i used on the 1979. with a mod of the engine case.
the ign start+dyn seems ready to b swapped, the flywheel i havw to try but i am confident. the tranny seems to fit.
so clutch+wheel+rtans will be 79.
i opened also the tranny because it howled and made too much metallic powder.
and because it was out for engine removal.
 i needed 140 deg celsius to get the axles out.
further is simple.
replace bearings.
if my arm is going allright or not do it anyhow.
wiemer an tommy the cat.
« Last Edit: May 21, 2007, 04:34:26 PM by wiemer »
« Reply #10 on: May 21, 2007, 05:13:27 PM »
Have you determined the cause of the howling?  Just worn bearings?
wiemer
« Reply #11 on: May 22, 2007, 01:41:21 AM »
I guess worn bearings; they had pretty much (axial) play, and one could tilt the axles much also.
the cogs look like new to me.
a strange pattern on the teeth though: oblique striping on some cogs! a line pattern some 30 degrees out of axle direction. :-? :-?
I am in the ordering phase now, also for the engine. (not muchneeded)
wiemer
