Author Topic: Fork extension clunk.  (Read 2347 times)
thrang
« on: May 17, 2007, 07:00:11 PM »
I got a bit enthusiastic riding home from work tonight and hit a wee hump on the road quick enough to lift the front wheel for a split second. As the forks shot out to full extension I was met with a strange clunking  sensation at the bars. Having rebuilt the Bimbo's forks a half dozen or so times and never felt this before I was wondering if the stronger springing could be showing up a worn rubber bumper washer that sit bellow the damper piston ring assembly? (the ones fitted are a couple that came out of a set of low mileage forks I got given and stripped down ages ago). Or is it a matter of messing round with the oil volume/weight to find out what suits the progressive springs?
Re: Fork extension clunk.
« Reply #1 on: May 17, 2007, 07:04:32 PM »
What weight oil did you put in the forks after your rebuild? I believe you said you put in less oil than the manual says to, if I recall correctly.
« Last Edit: May 17, 2007, 08:05:03 PM by Bob_Roller »
thrang
« Reply #2 on: May 18, 2007, 03:15:08 AM »
170cc, an 15 weight oil (what the progresive spring manufacture recomended).
Its not a problem as he handles fine but the clunk was a little disconcerting. My first thought was somethings worked lose slider, but all the bolts are tight and at the right torque settings.
thrang
« Reply #3 on: May 18, 2007, 08:43:16 AM »
Doh! I'm an idiot!
Took a good close look at the front end in the daylight and found the cause of my clunk. The fairing H bracketlower bolts were both lose and the clunking I felt through the bars was the fairing moving against the bracket slightly. Nothing to do with the forks at all!
Like I said I'm an idiot.
« Reply #4 on: May 20, 2007, 05:40:07 PM »
I love it when it's something simple, even if it does make me look like a goober...  ;D
thrang
« Reply #5 on: May 20, 2007, 07:39:29 PM »
Whats a goober?
« Reply #6 on: May 20, 2007, 08:16:40 PM »
Hmmm, would that translate to a "plonker"?  Somebody a bit slow and a bit dim, probably game from the TV series, "The Andy Griffith Show".  The town gast station attendent/mechanic wasn't the brightest bulb in the box and his name was Goober...
« Reply #7 on: May 20, 2007, 09:46:40 PM »
Goober = Somebody with fast hands and a slow mind.  In the aviation business we call him "Stanley".
Beware...
thrang
« Reply #8 on: May 21, 2007, 06:45:08 AM »
Basically a Wally then.
Goober, I'll have to remember that :D
