Author Topic: Ground Wire  (Read 1379 times)
Crossrodes
Ground Wire
« on: December 23, 2010, 02:07:35 PM »
I just noticed in a picture I took before I took my '79 apart that I had a ground wire attached to one of the studs on the rear coil.  Can anyone tell me what the other end of this ground with is attached to?
Re: Ground Wire
« Reply #1 on: December 23, 2010, 02:13:11 PM »
I don't have a bike with two coils, but from what I've seen in comments, the main grounding or earthing point for the electrical system is somewhere on the forward coil mount .
My best guess that the wire from your coil ends up somewhere at that point .
Is it a solid brown wire, or some other color ?
There should be a black wire on one of the coil terminals, it is the wire to the tachometer .
Re: Ground Wire
« Reply #2 on: December 23, 2010, 02:20:20 PM »
Here is a wiring diagram for a '79:
http://www.pbase.com/tomfarr/image/121670650
Re: Ground Wire
« Reply #3 on: December 23, 2010, 02:54:34 PM »
Mines a 79 twin coil i will check it out for you next week as the bike is tucked up in the workshop, but as i recall the brown is always earth.
When i did the rebuild i had a problem with wiring to the coils and both the Clymer and Haynes manuals diagrams didnt match to add to the confusion.
« Last Edit: December 23, 2010, 05:48:15 PM by Lucky_Lou »
Crossrodes
Re: Ground Wire
« Reply #4 on: December 23, 2010, 04:50:26 PM »
Here's the picture of the wire I'm talking about.  You can see it's a black wire and its grounded behind the stud holding the coil.   Looking at the bike now the only wire I can see that would fit goes from the battery negative post to a ground point on the transmission.
Rob thanks for the wiring diagram but those diagrams do not show the actual physical ground point connections.
« Last Edit: December 23, 2010, 04:54:50 PM by Crossrodes »
Re: Ground Wire
« Reply #5 on: December 23, 2010, 05:44:32 PM »
That looks like the main earth wire for the battery and should be connected from the -ve terminal to the bolt securing the speedo cable on the gearbox.I will put a picture up as soon as i can but maybe someone else can confirm this.
« Last Edit: December 23, 2010, 05:45:48 PM by Lucky_Lou »
Crossrodes
Re: Ground Wire
« Reply #6 on: December 23, 2010, 06:10:48 PM »
I thought it might be that Lou.  I connected it to the gearbox when I rebuilt the bike.  So somehow I did something right when I did the rebuild.
Re: Ground Wire
« Reply #7 on: December 24, 2010, 12:57:56 AM »
Yes - that is the main ground going to the battery.
The idea behind moving it is twofold:
1) to avoid stripping the aluminum threads in the transmission vent bolt
2) to get a more direct path for ground to the starter, but this location doesn't really accomplish that.
Thanks for the picture.  I never would have guessed you meant the main ground!
Re: Ground Wire
« Reply #8 on: December 24, 2010, 01:05:48 AM »
Yes - check and see if you have this wire, here:
Re: Ground Wire
« Reply #9 on: December 24, 2010, 05:51:16 AM »
Nice photo Rob but wheres the speedo cable ???
Re: Ground Wire
« Reply #10 on: December 24, 2010, 07:00:57 AM »
He's got a Vapor instrument cluster .
Crossrodes
Re: Ground Wire
« Reply #11 on: December 24, 2010, 10:19:05 AM »
Rob, thanks for the pic...yes that is where it is now connected.
Re: Ground Wire
« Reply #12 on: December 24, 2010, 03:36:28 PM »
I use my GPSr for a speedometer.
