Author Topic: vacuum ports  (Read 1261 times)
Vegasrandall
vacuum ports
« on: December 23, 2010, 07:59:22 PM »
does my 1980 w/ the smog fittings have vacuum ports for balancing the carbs?
Re: vacuum ports
« Reply #1 on: December 23, 2010, 09:45:07 PM »
If you have Bing CV carbs, the vacuum ports are on the bottom of the carb; usually closed off by a short, closed end rubber tube or a small screw.
Crossrodes
Re: vacuum ports
« Reply #2 on: December 24, 2010, 12:03:35 AM »
My '79 which has the flat top Bing carbs has a screw in a pipe at the bottom of the carb.  Your '80 may be the same.
Re: vacuum ports
« Reply #3 on: December 24, 2010, 01:09:23 AM »
Re: vacuum ports
« Reply #4 on: December 24, 2010, 07:05:02 AM »
Thanks for the photo, Rob. I searched my pic files for something similar and never found nada.
Vegasrandall
Re: vacuum ports
« Reply #5 on: December 24, 2010, 08:37:07 AM »
didn't peek under there,thanks
Re: vacuum ports
« Reply #6 on: December 24, 2010, 08:54:47 AM »
The 'search' feature ain't working for me.
I was looking for the El-Cheapo Bing Vacuum Adjustment Tool so Randall could get ready for a tune.
OK, here's the good one from Hugh Kenny of the Airheads Beemer Club:
http://www.airheads.org/content/view/183/98/
« Last Edit: December 24, 2010, 09:44:16 AM by montmil »
