Author Topic: Engine Removal Part 2  (Read 1201 times)
Nice_One_Son
« on: September 18, 2010, 02:33:18 PM »
Hi All,
Well, it's been a big day today, engine is now out and the wiring loom has almost been stripped out.
I got in contact with the original owner of the bike who is n engineer and he helped me get the engine out. It sure is going to be fun putting it back in, now I understand the part about lots of covering tape on the frame... :-?
Next up will be the bars, switchgear and then the front end.
Re: Engine Removal Part 2
« Reply #1 on: September 18, 2010, 10:05:03 PM »
And your shop helper brings you tea or coffee or...?
After painting the frame and ready to refit the engine, that's when the tape will be appreciated.
« Reply #2 on: September 20, 2010, 05:08:18 PM »
OOOOOgh! Original Shocks that are screeming "replace meeeeee"   ::)
« Reply #3 on: September 20, 2010, 06:50:21 PM »
Hagons would do nicely.     Monte
« Reply #4 on: September 20, 2010, 10:49:54 PM »
Carefully check the status of your centerstand mounts and pivot bolts while you've got everything this far apart - it is MUCH easier to fix up anything necessary in this condition (such as possible welding, bolt replacement (use the proper OEM or hardened bolt replacement (Grade 8, I believe)).
