Author Topic: Gearbox oil leak at shifter  (Read 688 times)
AndrewB
« on: August 04, 2010, 07:13:53 PM »
I have a slow drip oil leak coming from behind the gear shift on my 83 R65.
I went ahead and ordered part #23121338740- shaft seal from Max BMW.
Can I replace this seal by simply removing the gear shifter, etc from the exterior of the gearbox?
Or will I need to remove the gear box and get inside?
Re: Gearbox oil leak at shifter
« Reply #1 on: August 04, 2010, 07:36:08 PM »
With the bike on the center stand, when you remove the shifter linkage, you'll get maybe a cup of oil out of the transmission .
You can place a drip pan under the bike to catch it .
Simple straight forward procedure to remove the seal from the outside , no need to go into the transmission .
Make sure you get the seal in straight, or you could have shifting problems .
AndrewB
« Reply #2 on: August 05, 2010, 01:08:33 AM »
Thanks for the instructions Bob.
I gave the outer case a little heat with my heat gun, then tapped in the seal w/ a socket and rubber mallet.
Really straight forward, nice and easy! :)
