Author Topic: Rear tire removal  (Read 7820 times)
mimmo66
Rear tire removal
« on: July 26, 2010, 10:39:13 PM »
I wish it would be as easy to remove the rear tire as it is on the k bike.
What is your best method of removing the rear tire with the saddle bag mounts on?
I currently remove the front tire first, then tilt it forward and proceed.
Wish I could just do it in less steps! :-/
Re: Rear tire removal
« Reply #1 on: July 27, 2010, 12:11:14 AM »
That is how I do it.
I also let all the air out of the rear tire before I try to remove it.
Don't forget to tie your center stand cross-member to the front exhaust cross-over before tipping the bike forward.  The stand could fold up on you!
And don't leave the bike tipped forward with a full tank of gas.  (DAMHIK) ;)
« Last Edit: July 27, 2010, 12:15:35 AM by Rob_Valdez_79_R65 »
« Reply #2 on: July 27, 2010, 06:28:43 AM »
I was stumped the first time I tried a rear wheel removal. The riders handbook made it sound straightforward but it's not at all.
I remove the rear fender so the wheel can come straight out the back. It's just 4 nuts and the electrics unplug. I also need to let the air out too.
« Reply #3 on: July 27, 2010, 09:18:45 AM »
With most 110/90x18 rear tires, mine just slides right out with a nudge on the bike to make it tip forward on the centerstand - or, at least it does when there is no pannier rack bolted on (might require unbolting the left side half).     I imagine that if one has one of those "old man" ride-off centerstands you're basically stuck until you get a length of board to place under the centerstand to provide some extra height.
« Last Edit: July 27, 2010, 09:19:03 AM by nhmaf »
azcycle
« Reply #4 on: July 27, 2010, 05:06:08 PM »
This is good to know... I've got multiple projects ahead of me that I can tackle all at once.  Replace rear tire (120/90x18), replace brake pads, lube splines, replace rear fender, and replace/rewire the rear light. I think I'm toing to have to remove the sidebags, too.
I've never replaced a motorcycle tire myself but am seriously thinking about trying it, not only to save money but to have the knowledge.  Even buying tire levers (which I need anyway), tires, tubes, and wheel weights... I'm still probably cheaper than taking it to a shop.
« Last Edit: July 27, 2010, 05:07:30 PM by azcycle »
« Reply #5 on: July 27, 2010, 05:44:14 PM »
I wonder how hard it would be to put a hinge in the rear fender, so that it would fold up and out of the way.  I've seen that on older bikes.
« Reply #6 on: July 27, 2010, 07:42:50 PM »
I wonder how hard it would be to put a hinge in the rear fender, so that it would fold up and out of the way.I've seen that on older bikes.
Exactly why I have this picture in my library...
« Reply #7 on: July 27, 2010, 09:47:40 PM »
Does the 120/18 clear the swingarm OK?  I have a rear 120/18 Macadam for the Dawg but haven't tried the fit yet.
« Reply #8 on: July 27, 2010, 10:17:17 PM »
 A 120-18 Metzeler Lasertec will clear, but it's a pain to get it in, can't be done without deflating the tire first .
azcycle
« Reply #9 on: July 28, 2010, 01:11:11 PM »
I don't know to be honest. Right now the rear tire is Kenda 270 4.50x18 and it barely clears the swingarm... and chewed the heck out of the rear fender. So I was hoping the 120 was a bit more narrow.  Might go with a 110 then.
« Reply #10 on: July 28, 2010, 06:10:31 PM »
I believe the 110/90-18 works out to very close to stock.
mimmo66
« Reply #11 on: July 29, 2010, 12:40:07 AM »
I like the idea of the removing the rear mudguard much better than tilting the bike forward.
Will do some tryouts and see how it goes.
Domenico
San Jose, CA
Chris_in_BC
« Reply #12 on: July 29, 2010, 01:42:42 PM »
Strapping the centrestand to the cross-over (using one of the safety straps I have on all my pannier bags), then removing front wheel and tipping forward has always been the easiest way for me. This works just as well in the garage as on the side of the road.
Removing the rear mudguard and electrical connections seems potentialy messy and tricky on the side of the road.
Generally if using 120/90 x 18 tires you need the extra wide spacer sold by BMW that moves the wheel slightly out from the final drive.
« Reply #13 on: July 29, 2010, 02:57:40 PM »
Is this spacer on the axle?  If so I can machine one...
« Reply #14 on: July 29, 2010, 03:38:27 PM »
