Author Topic: Rear tire removal  (Read 7837 times)
Re: Rear tire removal
« Reply #15 on: July 29, 2010, 04:12:46 PM »
Justin,
I think the spacer, is the 'hat bushing', or a BMW calls it, a compression sleeve .
It is in the wheel bearing sleeve, spacer stackup .
Items 6 and 11 in the IPC reference .
I believe the outer bushing is longer than the inner bushing .
http://www.realoem.com/bmw/showparts.do?model=0365&mospid=47853&btnr=36_0151&hg=36&fg=10
« Reply #16 on: July 29, 2010, 05:10:56 PM »
So, I just need to machine a replacement for #6 that is longer by the amount of additional clearance I need and maybe make #11 the same amount shorter?
« Reply #17 on: July 29, 2010, 06:06:35 PM »
That sounds like that would work .
The outer bushing that I have #11, is 12.97 mm or .511 inches in length .
RealOEM shows the inner bushing to be 9.2 mm or .362 inches in length .
« Last Edit: July 29, 2010, 06:13:49 PM by Bob_Roller »
« Reply #18 on: July 29, 2010, 06:50:03 PM »
Bob, are yours offset for a wider tire?
« Reply #19 on: July 29, 2010, 07:13:07 PM »
No, the one I just got, is to install on the rear wheel, that was missing it after the previous owner had the wheels white powder-coated, and didn't install when he reassembled it .
I'm just wondering, if you could just swap the bushings that are already there, it would give you .150 inches additional clearance .
If you do this, make sure you have enough threads sticking out for the axle nut .
« Last Edit: July 29, 2010, 07:21:09 PM by Bob_Roller »
Chris_in_BC
« Reply #20 on: July 30, 2010, 02:12:57 PM »
Copying from Bob Fleischer's web site after a Google
http://bmwmotorcycletech.info/section5.htm
<<""Metric sized tires are what are generally installed.   A 90/90 or even 100/90 on the front, and a 110/90 on the rear.  In some instances SOME 120 will fit the rear; BUT, sometimes (pre-1981 for instance) one has to get the wider 10.7 mm spacer for the right side of the rear hub...BMW part number 36-31-2-301-737.    Stock was 9.2 mm, and was 36-31-4-038-142.    The spacers are VERY easy to install, and do NOT affect bearing preload.  "">>
Looking at MAX BMW site, the spacer part number  doesn't show up under R65 wheels but it does show up if you look at R100RS for 78 on
http://www.maxbmwmotorcycles.com/fiche/DiagramsMain.aspx?vid=51647&rnd=03192010
Justin, I don't think you need to reduce #11, the whole assembly just moves out slightly.
« Last Edit: July 30, 2010, 02:29:45 PM by Chris_in_BC »
« Reply #21 on: July 30, 2010, 03:30:40 PM »
There was a SI issued on tire clearance which suggests use of the 10.7mm spacer if necessary and also answers a question recently raised by bjamesw about how much offset is permissible.  The maximum is 4mm which is a lot less than I had thought it might be.
« Last Edit: July 30, 2010, 03:35:33 PM by bhodgson »
