Author Topic: leak  (Read 1175 times)
GrimReaper
leak
« on: July 24, 2010, 04:02:23 PM »
Hi all,this morning I found that I have a leak coming from the rubber boot between the tranny and the swingarm.Its a few drops,but I know it shouldnot leak.Any ideas what is goin on
Re: leak
« Reply #1 on: July 24, 2010, 05:15:30 PM »
Have you tried tightening the two clamps yet ?
GrimReaper
Re: leak
« Reply #2 on: July 24, 2010, 05:37:25 PM »
No,I did not think of that.I will give it a try tonight.
Re: leak
« Reply #3 on: July 24, 2010, 06:08:26 PM »
Give the rubber boot a good looking over, especially with the desert heat you have there, it speeds up the weather hardening and leads to cracking of the rubber .
GrimReaper
Re: leak
« Reply #4 on: July 24, 2010, 06:23:17 PM »
Bob, the rubber looks pretty good.I rode the bike for 700 miles since I got it last year.I will check the again.
Re: leak
« Reply #5 on: July 24, 2010, 06:31:14 PM »
Pray it's just the clamps.
Changing the boot requires removing the U-joint bolts, removing the swing arm pivot bolts, pulling back the swing arm, blah, blah, blah...
At least you'll get to practice and/or invent some new profanity while you work the boot and those two danged clamps back into proper position.[smiley=furious3.gif]
Or do as I did... if there is a crack or hole causing the leak, just rotate the boot to put the leaky spot on top. Rode for a year before fixing it correctly.
« Last Edit: July 24, 2010, 06:33:14 PM by montmil »
GrimReaper
Re: leak
« Reply #6 on: July 24, 2010, 06:55:27 PM »
Thanks Monte.If its cracked I will rotate it.Anyway this bike is my Sunday ride so I hope it will give me a year or two:)
fermin
Re: leak
« Reply #7 on: July 25, 2010, 08:57:55 PM »
Its a pain in the neck job and I just fixed my leak after weeks of trying different locations for the hose clamp screw.  It finally worked with the screw on the side.
GrimReaper
Re: leak
« Reply #8 on: July 25, 2010, 11:53:28 PM »
I tight the clamps this morning and its look like the leak is gone.Will see in a few days.
  Fermin my clamps screws are on the side also
