Author Topic: Crushed Oil Filter  (Read 7154 times)
Crushed Oil Filter
« on: March 20, 2010, 01:41:08 PM »
An unwelcome surprise greeted me when I changed the oil today. The pictures tell it all. Notice how the filter element has started to pull away from the end cap. You would think this might have caused low oil pressure but I've never noticed anything unusual. The oil pressure light went out instantly at start up and didn't so much as flicker even at very slow idle speeds of under 800 rpm.  I will drain the filter overnight and dismantle it to to see if it is badly clogged hopefully not with the metal from my bearings.
As to the cause :-
 The oil was 15W40 which should have been OK even at the sub zero temperatures we have had this winter.
 The oil had only been in approx 1700 miles and was not particularly dirty.
In my zeal to avoid the 2000$ O ring problem I removed the outer gasket at the last change and this may have put undue pressure on the filter as the O ring had been crushed square.
 Â
The filter is a Hiflo HF161 which may be suspect. Luckily I have a two piece filter as a replacement which should be stronger.
Anybody have any insights or had this happen to them.
« Last Edit: March 20, 2010, 01:49:02 PM by bhodgson »
Re: Crushed Oil Filter
« Reply #1 on: March 20, 2010, 02:04:16 PM »
Yep looks familiar. I thought I was clever using a Fram 6061 sourced from the local auto parts counter. The construction of your filter looks very much the same. Mine had no support ring in the middle of the filter and came out as flat as Kansas. I've since switched to the OEM.
« Reply #2 on: March 20, 2010, 02:08:57 PM »
I take it your engine survived OK ?
I know there is a bypass valve to keep the oil circulating in case the filter should get blocked.
« Reply #3 on: March 20, 2010, 02:45:25 PM »
I did some inquiring about 4 months ago, about installing an oil pressure indicator on my '81 R65 .
The response I got, was that on a cold start-up, oil pressures are at least 100 psi on an airhead bike of our vintage in the 40-50 F. temperature range .
I think it would be wise to stay with the OEM hinged style filter, due to their short length of filtering media between the metal end supports .
Offline Mike V
  • 78 R100/7 , 81 R65
« Reply #4 on: March 20, 2010, 03:42:42 PM »
Barry,
From Snowbum's site...
"NOTE:  If a filter should collapse, due to faulty manufacturing...perhaps a lousy central metal tube in the filter itself?...or maybe excessive end pressure in installing(??).....the canister bypass valve should...one hopes...allow engine oiling.  Have been at least TWO reports of filter failures ruining  engines.  I suggest using ONLY BMW filters, or the Purolator.  I am sorry to say that FRAM filters...including their car filters...seems to be of questionable quality these days.   I think the hinged filters are stronger as I have noted, above... certainly easier to use."
I would try a new OEM filter as Bob states and as a lot of the responses indicate.
« Last Edit: March 20, 2010, 03:52:31 PM by Mike_V »
Mike V. / San Diego
'78 R100/7 (original owner)
'81 R65 (fully restored)
« Reply #5 on: March 20, 2010, 03:59:18 PM »
Thanks Mike.
I looked at Snowbums site but missed the bit about "excessive end pressure in installing". Well I certainly had excessive end pressure and I guess once the filter pleats get kinked they will fold flat under the oil pressure and tend to crush the central tube. That together with a non oem filter that had no additional support ring inside the tube must have been the cause.
I will measure the canister depth carefully this time and use the outer gasket if the calcs indicate it is required.
I've already dismantled the filter and as far as I can see there are no bits of metal on the element so it looks like I got lucky.
« Reply #6 on: March 20, 2010, 04:03:50 PM »
Although it looks mighty scary, the filter was likely passing oil along with help from the oil bypass valve. I run the two-piece hinged filters, those aka: bendys. Besides being easy to install, they seem quite strong in compression.
Check the bum's site and the ABC tech section for an easy way to measure the filter cavity depth so as to know if a paper gasket or +/– shims are needed. At 1700 miles, the O-ring ought to have had enough elasticity to return to a fairly rounded cross-section. Your particular filter may have needed the gasket so all the more important to use a vernier to measure for the new bendy.
Did the filter cover plate "pop" out as the bolts were removed? Cold temps could easily have created higher than normal pressures. Perhaps an electric "snuggy" or warm lightbulb for the scooter?
Post up what you find, if anything, inside the filter. Likely nuttin'.
Offline Mike V
« Reply #7 on: March 20, 2010, 05:57:12 PM »
Barry,
I agree with monte, there's been lots of talk regarding this subject on the ABC LIST in the past and there's some comments saying this really does look worse than it is regarding any resulting engine damage.  But still a good idea to check the canister depth carefully for proper filter compression and always use BMW OEM filters.  These are items that are important enough where a dollar saved is not necessarilly a good idea. You'll find lots of different ways of doing it, I believe Oak has his percent procedure and formula (I have it somewhere, if you need it let me know and I'll hunt it down) or you can use Anton's chart which is also great...
http://www.largiader.com/tech/filters/canister.html
Probably a good idea to do a thorough inspection of the filter element by cutting it away from the housing.  Bum has instructions on his site.  I find myself doing this now after every filter change, it just makes better sence than just throwing the filter out and not knowing if something is going wrong.
Mike V. / San Diego
« Reply #8 on: March 21, 2010, 11:24:25 AM »
Thanks guys
Good new is there was very little on the filter element 2 or 3 very small bits of metal no more and maybe less than last time when I stripped and inspected the filter. I did measure the canister depth last time too but got something wrong .
After reading Snowbum and Anton Largiader yet again to make sure I get it right this time I've come to this simple conclusion
The O ring must be under enough but not too much compression in the range 0.2 - 0.8mm
and
you must measure your own gasket and O ring thickness which may differ from Antons Figures.
My gasket was thicker and O ring thinner than I had assumed.
I had 3 new filters on the shelf 2 of which are the same make and they are all different lengths varying by upto 2mm.
By trial assembly without the O ring in place I have  concluded that the ideal length including end seals is 129.5 mm but this would be 0.55 mm less if the gasket was not used! This really does suggest that OEM filters maybe best.
Here's my simple speadsheet for calculating the O ring compression.
My canister depth is 3.0 mm so I do need the gasket and have fitted it his time.
« Last Edit: March 21, 2010, 11:29:04 AM by bhodgson »
« Reply #9 on: March 21, 2010, 11:40:51 AM »
How consistent are the lengths of the rubber 'tube' type seals, at each end of the oil filter ?
« Reply #10 on: March 21, 2010, 11:49:52 AM »
Bob
The rubber seals were all the same length even from different makes of filter.  It was the canister length that varied probably due to the amount of bonding material used at the end caps.
2 of these filters came with a job lot of new spares I got off ebay which at the time seemed good value. I got a set of genuine points, 4 sparkplugs, a set of brake pads and 2 oil filters for £12 so Im not out of pocket if I trash the filters.
« Reply #11 on: March 21, 2010, 05:40:55 PM »
A search on the Airheads list has turned up a few things worth sharing :-
This doesn't just happen to none OEM filters there were several examples of genuine BMW filters having collapsed including more than one example of a BMW bendy filter.
Possible causes suggested were failure to prime the oil filter cavity before starting (not guilty)  and excessive revs with cold oil (I keep below 4000 rpm but that's enough to produce 120 psi oil pressure according to one poster).
Thought you might want see a final picture... sleep well, odds are yours is not like this.
« Last Edit: March 21, 2010, 05:51:36 PM by bhodgson »
Offline Mike V
« Reply #12 on: March 23, 2010, 01:14:06 PM »
Barry,
Good stuff. I never thought to measure the new shims and o-rings out of the box. (Duh) Thanks for the heads-up and chart.
Don't forget to always use the metal shim on sharp canisters to protect the o-ring. I believe the rounded canisters started in the mid to late 80's. Don't know of a definate date on that.
Mike V. / San Diego
« Reply #13 on: March 23, 2010, 08:12:12 PM »
Well this is scary!
I have NEVER primed the filter cavity on an oil change.  I don't recall seeing anything in the owners manual about it.  I could easily be wrong.
« Reply #14 on: March 23, 2010, 08:24:13 PM »
I got into the habit with all of my vehicles about 30 years ago, to operate the starter, until the low oil pressure light extinguishes, after an oil and filter change .
Usually remove the fuse for ignition, or in the case of the R65, remove the spark plug leads, and put an old set of plugs into the leads, and put the plugs on the cylinders, and operate the starter .
Don't know if it has made a difference or not !!
