Author Topic: fork oil  (Read 766 times)
manxr65
fork oil
« on: March 30, 2010, 12:25:54 PM »
please can anyone tell me how much fork oil to put in each leg and what grade 10 or 15 etc.
thanks
79 r65
Online Bob_Roller
Re: fork oil
« Reply #1 on: March 30, 2010, 01:52:57 PM »
If you are just draining and refilling the forks, 190 ml of oil is required per fork leg, if you disassembled the forks, for a seal change, bump it up to 220 ml .
The standard fork oil for the R65, is 7.5 wt, only available from a BMW dealer, or repair shop, haven't seen it anywhere else .
If you can't source it locally, 10 wt oil will work as well .
Re: fork oil
« Reply #2 on: March 31, 2010, 03:43:06 AM »
Also if you can't get 7.5 wt it's perfectly OK to blend 5 wt with 10 wt but you must to stick to the same brand for consistent results.
A way of checking for the correct amount of oil is to use something like welding rod as a dipstick. With the forks fully extended your dipstick can be lowered through the filling hole and should measure a level of 35mm + or - 15mm
« Last Edit: March 31, 2010, 04:00:45 AM by bhodgson »
Re: fork oil
« Reply #3 on: March 31, 2010, 12:22:34 PM »
Bob Is The Oil Guy is a really informative website about lubricants.
http://www.bobistheoilguy.com/cms/
This will tell you more than you could ever have possibly wanted to know about lubes.
