Author Topic: Bean can lube  (Read 625 times)
Offline BooG
Bean can lube
« on: February 27, 2010, 02:32:09 PM »
Whats the best lube to use whilst re-assembling my bean can? Where do you lube?
Ta!
BMW R65 1980.
Vespa Sprint Veloce 1971
BMW K75S 1987
Re: Bean can lube
« Reply #1 on: February 27, 2010, 05:17:37 PM »
I like to use just a wee bit of white lithium grease on the advance weight pivot posts. Not necessary to lube the nylon "feet" on the weights as they will slide naturally across the floor of the advance mechanism.
A little wipe of oil on the steel components will help keep rust at bay and a drop or two of oil on the washer stack at each end of the shaft is nice. I tend to put a couple drops of oil on the sealed bearings just to help me feel good about it.
