Author Topic: Can find it so Ill ask  (Read 1086 times)
chewy4x4
« on: January 21, 2010, 11:00:26 PM »
Can any one point me in the direction of some easy rearsets
Re: Can find it so Ill ask
« Reply #1 on: January 21, 2010, 11:14:49 PM »
I haven't used these, but they are regular advertisers in the BMWMOA magazine:
http://www.rearsets.info/
« Reply #2 on: January 22, 2010, 05:35:18 AM »
GrimReaper
« Reply #3 on: January 22, 2010, 11:08:06 AM »
chewy4x4
« Reply #4 on: January 22, 2010, 01:43:22 PM »
Ok Thanks yall how about what handlebars will fit these bikes like r100rs or f650
« Reply #5 on: January 22, 2010, 02:39:37 PM »
I am using a Raask rearset that I purchased used from the BMWMOA classifieds and it is specific to the R65. Bolts right up no problem. The link in the first reply for Omar's  has them at the top of the left hand column. The biggest issue is the rear brake since the lever goes through a pocket in the frame. Anything modified to fit will be a problem there. Not impossible but much easier if it is already to bolt up.
« Reply #6 on: January 22, 2010, 04:45:04 PM »
Here is a link from Omar's to a pic of the R65 rearsets. You can see the lever that is needed to connect the rear brake.
http://www.rearsets.info/F4.JPG
