Author Topic: What model?  (Read 3374 times)
azcycle
What model?
« on: December 07, 2009, 05:22:03 PM »
I know this isn't about the r65 model, but John (my fiance's recently deceased father) has another BMW bike at his property.  I'll post a pic of the bike in it's chopper form... sometime back in the late 60's or early 70's (I think).
We actually still have that frame, rear wheel/tire, rear fender and engine/transmission. Also have a couple BMW gas tanks (not in that picture) and some miscellaneous engine parts/heads in another box but I honestly don't know what year/model BMW it is.
Just comparing photos online to that chopper photo, it looks to be a 67-69 r50 perhaps?  Would I be able to find some sort of model/engine ID numbers anywhere?  If so, where would they be located?
« Last Edit: December 07, 2009, 05:22:47 PM by azcycle »
Re: What model?
« Reply #1 on: December 07, 2009, 05:37:53 PM »
Check the engine crankcase down low, near the oil pan. Check the headstock area for a frame number.
With that rear suspension, the front end was likely an Earles Forks front suspension. Same as Bengt Phorqs son's name, so Mike claims.
Re: What model?
« Reply #2 on: December 07, 2009, 05:58:03 PM »
If you get the numbers off of the frame and engine, you can go to RealOEM.com and put the last 7 characters into the appropriate search box, and it will give you the year of manufacture, and model  of the bike .
http://www.RealOEM.com/bmw/select.do
« Last Edit: December 07, 2009, 05:59:06 PM by Bob_Roller »
Re: What model?
« Reply #3 on: December 07, 2009, 07:51:58 PM »
Ewwww, that is one butt ugly bike!  If it was a dog I'd shave it's tail and make it walk backwards.  Check out the frame and engine s/n's like Bob & Monte suggest and you'll be able to nail it down.  The frame looks almost like a Moto Guzzi loop frame from the '60's, like an Ambo or an Eldo.   No doubt you have some good parts there that could be salvaged.  Consider parting it out unless you want to get it running and then it would be a conversation piece for sure. [smiley=2cents.gif]
Re: What model?
« Reply #4 on: December 07, 2009, 07:55:26 PM »
If the engine is sound, I would restore it back.
azcycle
Re: What model?
« Reply #5 on: December 07, 2009, 08:46:36 PM »
John kept telling us he was going to rebuild it back to stock for his daughter (my fiance) so she may want to keep it. I am fairly mechanically inclined but not sure I could take on a complete restore/rebuild of this magnitude. Thanks for the advice, all. I'll check for serial/ID numbers and see what it comes up with.
Bengt_Phorqs: It might not be too pretty to look at, but John built that up as a teenager out of the parts he could get.  Despite building award-winning bikes, I know John always had a special place in his heart for this early monster. ;)
Re: What model?
« Reply #6 on: December 07, 2009, 09:02:00 PM »
That does definitely look like a /2 frame, but I think it has had some modifications in the rear end around the fender/seat/upper plunger area, poor thing.   That ooga-ogga rubber bubl horn would have to be the first thing to go... :D
Re: What model?
« Reply #7 on: December 08, 2009, 07:27:49 AM »
Bengt_Phorqs: It might not be too pretty to look at, but John built that up as a teenager out of the parts he could get.Despite building award-winning bikes, I know John always had a special place in his heart for this early monster.
Graeme, you are absolutely right, beauty is in the eye of the beholder.  For example, Mrs. Phorqs keeps telling me "you shore are purty" and I tell her she's blind in one eye and can't see out of the other, so it's all subjective.  My apologies.
azcycle
Re: What model?
« Reply #8 on: December 08, 2009, 11:38:09 AM »
Oh, no offense taken. :)  I'm sure John looked back and cringed a bit when he saw the photo, too... considering what he was able to build later in life.
azcycle
Re: What model?
« Reply #9 on: December 14, 2009, 02:01:27 PM »
Well, I snapped some photos this weekend of the engine, frame and misc parts but couldn't come up with ANY Id numbers anywhere. I unfortunately forgot to upload them to my online album so I can't show them now, but I'll upload them tonight.
The rear fender that is on the frame now is different that what is shown in that old photo.
The frame seems solid, but has a bit of surface rust. I think once the project begins, I'll have it sent out and blasted/powder coated.  That is, if I can actually get a title for the frame without any numbers...
Re: What model?
« Reply #10 on: December 14, 2009, 02:18:20 PM »
I would contact the Arizona MVD, and ask them about it, but with my experience with them, chances are real good, you're going to hit a wall real quick with them .
When I tried to transfer title and registration from Illinois, to Arizona, I had a 2 month battle with the MVD, all over the fact, that the foil sticker on the frame tube on the right side of the bike, wasn't legible .
I think MrRiden had a similar experience, when he bought his LS a few years back .
darrylri
Re: What model?
« Reply #11 on: December 14, 2009, 08:45:25 PM »
It does indeed look like an R50.  The motor number should be on the right side above the pushrod tubes.  The frame number should be on the right side of the steering head running sideways.
You can see where the numbers are here on my '61 R60/2.  (Sorry not to directly display this, but it's biggish and will screw up the forum formatting.)
The frame appears to have the lugs for a sidecar -- if it does, it was an Earles fork bike.  If not, it was an R50US with the  pre-/5 telescopics.
If you get into this, you might be interested in joining the Yahoo slash2 email list (http://groups.yahoo.com/group/slash2).
« Last Edit: December 14, 2009, 08:45:58 PM by darrylri »
azcycle
Re: What model?
« Reply #12 on: December 14, 2009, 10:43:14 PM »
Thanks everyone!
Ah, I bet I just stupidly overlooked the numbers... they're obvious on your engine.  Here are a couple pics as it stands now. The huge gas tank is just sitting on the frame. John had a couple BMW tanks lying around.
And here is a hidey-hole of BMW parts I found. Is that the transmission there in the back/left?
Oh, and just for fun... here is John with my fiance Trish as a little girl, on this BMW sidecar outfit he custom built. Taken in New York around the late 80's, when the bike wasn't complete. This bike is now at a motorcycle museum in Japan.
Here is a Hack'd Magazine Cover with John on his bike before it went to Japan:
Anyway... thanks for the advice, fellas.  Will update as I research more.
Re: What model?
« Reply #13 on: December 15, 2009, 12:13:33 AM »
What a great collection of stuff!
Those fuel tanks are currently going for AT LEAST $2000 US or better on eBay.  Congratulations!!!
azcycle
Re: What model?
« Reply #14 on: December 15, 2009, 11:39:34 AM »
You're kidding, right? Holy cow... John told me that tank was valuable but I had no idea. :o  He told me the story of him buying that tank off a guy in New York where he grew up.  Saw it sitting on the guy's front porch, stopped, and talked him into selling it for $20 or something absurd. Guess the guy didn't know it's value!
