Author Topic: Seat and Cover  (Read 1283 times)
Nice_One_Son
Seat and Cover
« on: September 21, 2009, 03:24:10 AM »
Morning All,
I took the seat off this weekend (along with a few other bits!) and found the underside of the seat has a lot of rust, we removed the back panel and are now left with the seat covering pop rivets/small metal panels holding the seat cover on. I need a new seat cover, so want to remove seat cover to renew and then restore the seat frame itself.
Do I drill the rivets out and then separate the covering from the frame?
My manual (Clymer) does not seem to cover this bit!
Thanks
Re: Seat and Cover
« Reply #1 on: September 21, 2009, 06:37:50 AM »
Yes You need to drill out the rivets and re-use the metal strips when you fit the new cover.  It's likely some of the rivets will spin so go easy and use a sharp drill.
The cover is also glued on so you will need some sort of impact adhesive.
Nice_One_Son
Re: Seat and Cover
« Reply #2 on: September 21, 2009, 06:56:08 AM »
Thanks Barry!
Re: Seat and Cover
« Reply #3 on: September 21, 2009, 12:27:14 PM »
I think there is a write up on fitting a new seat cover somewhere on the forum. You might want try a search. If not a few of us have fitted new covers and will chip in when you get to that stage. You'll be needing quite a few strong bulldog clips or something similar to hold the edges as  you stretch it to fit.
Re: Seat and Cover
« Reply #4 on: September 21, 2009, 05:40:12 PM »
Check the Gallery for quite a few photos and tips on my R65 seat recover. Gallery is "montmil".
http://cgi.ebay.com/ebaymotors/1981-86-BMW-R65-SEAT-COVER-do-it-yourself-installation_W0QQcmdZViewItemQQ_trksidZp4634Q2ec0Q2em14Q2el1262QQhashZitem5630e48f25QQitemZ370187472677QQptZMotorcyclesQ5fPartsQ5fAccessories
NW Classic Motorcycle Seat Covers offers a fine product and after several months of use and minor abuse, I can say I'm totally pleased with the product.
