Author Topic: instrument housing repair  (Read 1358 times)
Offline Bill Conquest
« on: September 17, 2009, 10:29:30 PM »
Quite awhile back someone posted a repair made on a broken  rubber instrument housing that looked good.. it was broken right at the narrow spot on the side - same as mine - any idea where that post is, I can't find it.. or does anyone have an idea on this? What glue would work? Thanks, Bill Conquest
79 r65/75 r60/76r75/76r100
Re: instrument housing repair
« Reply #1 on: September 17, 2009, 11:16:39 PM »
I can't link to the page, but if you go back 9 pages in this section, it's under the heading dash panel, started by Dav, 07/11/09 .
« Reply #2 on: September 18, 2009, 09:19:02 AM »
« Reply #3 on: September 18, 2009, 10:06:59 AM »
Yeah, that's the one, thanks !!!
Has anyone found an adhesive that will melt the rubber/plastic material that this panel is made of  ?
The '84 LS panel needs a repair done to it .
« Last Edit: September 18, 2009, 10:08:33 AM by Bob_Roller »
« Reply #4 on: September 18, 2009, 11:06:09 AM »
Mine looks perfect from the outside but when I take it off I can see it has started to split from underneath.
I guess NOW is the time to carry out a repair/reinforcement
« Reply #5 on: September 18, 2009, 03:24:07 PM »
Thanks alot for the help, everyone.. i'm fixing this while re-building my brake m. cylinder, since its all apart. Sounds like this is a common thing to happen & new housings are expensive! I'm still wondering about what adhesives to use..
Bill Conquest
bruce_launceston
« Reply #6 on: September 18, 2009, 08:41:32 PM »
I plastic welded mine from the back with a soldering iron and have reinforced it with araldite epoxy.
« Reply #7 on: September 19, 2009, 04:25:52 AM »
Well, i've embarked on a repair using aquaseal & dowels to fix this - the dowels are used as in a cabinet face frame joinery fashion, difficult because there isn't much thickness to deal with, but it seemed to work. Aquaseal is a product used to glue rubber type stuff - wetsuits etc. I use it to fix kite bladders( kitesurfing) & it works well. It will be interesting to see if & how long it works for, will report back!
Bill Conquest
Offline dav
  • gotta luv the boxer
« Reply #8 on: September 19, 2009, 04:41:56 AM »
Bill Conquest
hope it works for you mate, still have't got around to do mine yet, but i'll get there oneday, what day month year that will be i dont know ::)......it'll be good to hear how yours turns out [smiley=bmw_smiley.gif]
BMW R65 ?1981
Ducati 1968 250 mk lll
Suzuki DR250 1983
Yamaha XT250 2015
« Reply #9 on: September 19, 2009, 04:44:48 PM »
I'll let you know how it goes together, & see how long it lasts!
