Author Topic: Broke Alternator Brush  (Read 764 times)
Offline R65Singh
« on: September 03, 2009, 08:12:44 PM »
Hello All...was working on my bike and putting all the things together after installing timing chain and dropped the alternator and broke one of the Carbon brushes >  :(.  Not sure if I can just buy one brush or the whole unit needs to be replaced. Any ideas?...Thanks
1982 R65LS
1970 r50/5
1962 r50/2
1976 Honda Z50
Re: Broke Alternator Brush
« Reply #1 on: September 03, 2009, 08:40:30 PM »
If you have an alternator/generator/starter repair shop in the vicinity, stop by with the brushes, they should be able to supply a replacement set, for minimal cost .
I would replace both brushes, instead of just one .
Worse case scenario, Motorrad Elektrik, Euro Motoelectrics can supply them for around $10 for a set .
www.motoelekt.com
www.euromotoelectrics.com
« Last Edit: September 03, 2009, 08:45:17 PM by Bob_Roller »
« Reply #2 on: September 04, 2009, 06:06:38 PM »
They're cheap. Just buy a pair and refresh both. Then you will avoid having to remember which one will wear out first. ;)
I find a small butane soldering torch makes quick work of soldering on the new braided wire leads.
