Author Topic: How hot do does your coil get?  (Read 965 times)
Offline beemer
  • The Red Tomato!!!
« on: July 11, 2009, 09:59:26 AM »
Wondering how hot your coil get's after a good run on your bike,mine is as hot as hell!!!i know they give high output,but it seems very hot to me!!!let me know,Julian.
Re: How hot do does your coil get?
« Reply #1 on: July 13, 2009, 01:25:32 PM »
To be honest, it's never occurred to me to feel my coil after a ride.  What prompted you to?
Offline beemer
  • The Red Tomato!!!
« Reply #2 on: July 13, 2009, 05:37:41 PM »
I had a earlier K100 coil i use on my R65LS,i managed to get the later version with the brown lead connectors,but it get's hot!!!the  one i was using was the older,but much larger black type,nothing wrong with it,i just changed it over,and noticed the heat!!the black one gave a reading of 2.0ohm,the new one 1.9ohm,both work fine,i think you don't want to go lower then 1.5ohm,but higher is ok with the electronic ignitionJulian.
« Last Edit: July 13, 2009, 05:40:58 PM by beemer »
