Author Topic: Dash panel  (Read 997 times)
Offline dav
  • gotta luv the boxer
Dash panel
« on: July 11, 2009, 06:55:27 AM »
Hi guys, does anyone know how much a dash panel cost..could't even find on the net :o..
my panel is abit well, cracked..here's a pic of it.
cheers :)
BMW R65 ?1981
Ducati 1968 250 mk lll
Suzuki DR250 1983
Yamaha XT250 2015
Re: Dash panel
« Reply #1 on: July 11, 2009, 07:56:22 AM »
Cost is around $170US, BMW part number : 32711236896 .
I'd be cautious of buying one used, as they all seem to break, so if you do decide to get one, don't pay much for it .
« Last Edit: July 11, 2009, 07:57:28 AM by Bob_Roller »
Yikes
Re: Dash panel
« Reply #2 on: July 11, 2009, 08:56:26 AM »
The least expensive new one I've found is at Motobins.  I've just learned to live with my cracked panel.
larstorders
Re: Dash panel
« Reply #3 on: July 11, 2009, 09:26:38 AM »
Effective dash panel repairs, with pictures, and the non existance of new replacements has been covered recently on this forum. You should find it with a search. Good luck.
Re: Dash panel
« Reply #4 on: July 11, 2009, 10:20:12 AM »
I would try to get an adhesive that melts the material, as just putting on an epoxy or like material, will just fail again .
larstorders
Re: Dash panel
« Reply #5 on: July 12, 2009, 10:58:51 AM »
Here again is a good fix which is very, very, strong. Mine has stood the test of time, 18 months, 7,500 miles and on and off countless times during fairing fitting, until 3 months ago. It now lives in the shed because I have   completely changed the dash setup for a more harmonious fit with my RS fairing.
 A 1.5 mm mild steel strip, cut and shaped appropriately.
Heat up the metal strip and burn a slot into the rubber to accomodate it. When all is cooled down, install the steel strip with epoxy and hold the rubber pad together using elastic bands etc. Depending on previous damage to the pad an almost invisible super strong mend can easily be achieved.
Shame about the gunge already on the face of your dash pad. Good luck with your repair.
« Last Edit: July 12, 2009, 10:59:36 AM by larstorders »
