Author Topic: Timing light advance degrees setting?  (Read 877 times)
clouseau
« on: June 13, 2009, 06:50:08 PM »
I can't find what advance degrees to dial my timing gun to, to check the timing on my 82 R65LS w/ electronic ignition.
Does anyone know the setting by chance.  Clymer is no help on this one.
Thanks so much!
Re: Timing light advance degrees setting?
« Reply #1 on: June 13, 2009, 08:01:43 PM »
I am not completely, 100% certain, but I believe that the static timing for all post  1980 airheads is 6 degrees BTDC, with full advance at 26 degrees.
« Reply #2 on: June 14, 2009, 03:03:19 PM »
My handbook says 6 deg BTDC static and 32 Deg BTDC at full advance (6 + 26).
I find it pinks a little at these settings using 95 Octane unleaded so I Retard another 1.5 - 2 Deg.
« Last Edit: June 14, 2009, 03:21:51 PM by bhodgson »
clouseau
« Reply #3 on: June 14, 2009, 10:00:22 PM »
Thanks!
