Author Topic: Cheap, effective manometer  (Read 4608 times)
« on: May 10, 2009, 07:09:11 PM »
This DIY manometer was copied from an idea from the Power Parachutes company as a simple method to confirm Bing carb synchronization prior to flight. Some ultralight flyers mount the tubing to the airframe and do away with the yardstick.
All I had to buy was twelve feet of 3/16' ID vinyl tubing. Everything else was in the shop.
The fluid is BMW brand 7.5 wt. fork oil. The purple color is a bonus as it's easy to see. I figure that makes the stick an official BMW tool. Add enough oil to have about 12-inches in the tubing. Attach each open end to the vacuum ports on the bottom of both Bing carbs. Support the stick in a vertical position and you're ready to "simonize" those carbs.
Re: Cheap, effective manometer
« Reply #1 on: May 10, 2009, 07:32:33 PM »
What you have done is re-invented the $2 carb synchronizer!  I'm gonna have to break down and build one since my dual vacuum gauge brainstorm flopped...
« Reply #2 on: May 11, 2009, 05:42:28 AM »
...then shop the Big Box stores. I paid $0.23/foot for the tubing at Ace BMW Supply & Hardware. So my two-buck manometer cost me a bit more. They do work quite well.   Monte
Offline beemer
  • The Red Tomato!!!
« Reply #3 on: May 11, 2009, 06:40:40 AM »
It's a great item to make!!!here's mine,made it about a year ago.
« Reply #4 on: May 11, 2009, 09:25:22 AM »
Even when inflation (since the original) is taken into account you came out well!
« Reply #5 on: May 11, 2009, 09:57:50 AM »
One of my favorite tools! Here's my fancy schmancy version
« Reply #6 on: May 11, 2009, 11:25:55 AM »
Hopefully there aren't any NY troopers here to notice your "borrowed" New York state highway sign !
« Reply #7 on: May 11, 2009, 11:30:02 AM »
I was thinking along similar lines in that they are probably glad he lives somewhere else!
« Reply #8 on: May 11, 2009, 03:28:50 PM »
Sign is from the 30's, design long ago rendered obsolete. Did I mention it fell off a truck. ;) Every NE transplant that walks by while the bay door is up stops and chats when they see it. Now I want a California Rt 1 sign to go with it. Back to manometers, here is a different take on a differential manometer
« Last Edit: May 11, 2009, 03:30:00 PM by MrRiden »
« Reply #9 on: May 11, 2009, 04:36:04 PM »
whats the best way to attach it to the carbs??
« Reply #10 on: May 11, 2009, 04:57:17 PM »
There is a barbed fitting on the bottom of each carb, that you attach the hoses to.
« Reply #11 on: May 11, 2009, 05:46:56 PM »
Look for a closed-end rubber tube about 20mm long on the bottom of the carb body. Or, you may have a screw in the vacuum take-off tube, same location. FYI, It's an odd thread so don't lose it.
Using the DIY el cheapo grande manometer, both carbs should be hooked up during the synchronization operations.
« Last Edit: May 11, 2009, 05:47:39 PM by montmil »
« Reply #12 on: May 11, 2009, 06:33:56 PM »
Only one way. Connect both ends before starting!! hook 'em up here
http://www.webbikeworld.com/Motorcycle-technical-articles/pulse-air/vacuum-takeoff.jpg
« Last Edit: May 12, 2009, 10:21:55 AM by MrRiden »
« Reply #13 on: May 12, 2009, 01:10:59 AM »
Rich, looks like some new-fangled still design!  ;D
