Author Topic: Odometer stopped working and started again.  (Read 2158 times)
VaSteve
« on: April 18, 2009, 06:36:05 PM »
I went for a nice long ride and found that my odometer stopped (I compared it to the bike computer I have on the handlebars).  Originally, I though the bike computer had gone haywire, so I watched the odometer for a while and it didn't change at all.  Then it did.  I went right on trucking like nothing was wrong.  I didn't touch or otherwise do anything to it.  What do you think happened?
Re: Odometer stopped working and started again.
« Reply #1 on: April 18, 2009, 07:18:48 PM »
One cause of odometer malfunction is a little gear inside that slips out of contact with it's mating gear.  It sounds like yours is right on the verge!
VaSteve
« Reply #2 on: April 18, 2009, 07:47:16 PM »
I had this problem in my 944 and I was able to buy a new gear.  Is there any such replacement or do I have to ship it to VDO/North Hollywood Speedometer to fix it?
« Reply #3 on: April 18, 2009, 08:15:37 PM »
Unless you have a donor speedometer, parts are not available for the internal workings.
If you don't feel like going into the speedometer yourself, typical repair for this is around $180-200.
This usually includes a thorough cleaning, and recalibration.
I was bored at work about a month ago, and found a repair shop in your general area that does repairs on BMW motorcycle speedometers.
Southern Electronics in Richmond, VA.
http://carradio.com/
« Last Edit: April 18, 2009, 08:20:02 PM by Bob_Roller »
« Reply #4 on: April 18, 2009, 10:45:25 PM »
Normally the gear just slips back and you can slide it back where it belongs and put on a drop of adhesive to help keep it put...
drewboid
« Reply #5 on: April 20, 2009, 11:15:52 AM »
One of the gears slipping on the shaft is the usual cause - see:
https://www.airheads.org/index2.php?option=com_content&do_pdf=1&id=160
for repairs.
VaSteve
« Reply #6 on: April 20, 2009, 06:33:46 PM »
for repairs.
Cool, good find, but....were there supposed to be photos?
drewboid
« Reply #7 on: April 21, 2009, 07:50:24 AM »
Yes there should be photos - try this link
http://www.airheads.org/content/view/160/98/
good luck.
VaSteve
« Reply #8 on: April 21, 2009, 08:14:48 PM »
Cool, thanks.  That's similar to the 944 I worked on, but looks sturdier!
