Author Topic: Magura 15mm Master Cylinder Reservoir Retaining Screw  (Read 987 times)
Offline dostoy320
« on: July 15, 2026, 08:23:56 AM »
Hello,
That small screw that retains the plastic reservoir body from the underside of the master cylinder is missing on the R65LS I just purchased. Does anyone know the correct screw dimensions? It isn't labeled on any of the parts fiches I've found.
I'm assuming something very short and course threaded.
« Last Edit: July 15, 2026, 08:25:29 AM by dostoy320 »
Offline Tiedie
Re: Magura 15mm Master Cylinder Reservoir Retaining Screw
« Reply #1 on: July 15, 2026, 11:14:17 AM »
https://shop.maxbmw.com/fiche/DiagramsMain.aspx?vid=51899&rnd=10232024
It's part # 222 here at Max. Either give them a call or call EME and they should be able to get 1 out to you. I don't think I can size it on the spare Master cylinder I have. I can look but it might take a bit to get back to you.
Offline dostoy320
« Reply #2 on: July 15, 2026, 03:10:34 PM »
Thank you! The image of the screw against a ruler at the link you provided is likely enough for me to find the equivalent at the local hardware store.
I do appreciate it!
Offline Tiedie
« Reply #3 on: July 15, 2026, 04:51:27 PM »
 :thumbsup: I have a 84 LS and rebuilt the front brakes I do have the master cylinder afew months ago and I got what you need. I can send it to you. Or if you need the the whole reservoir pictured. We can work something out.
« Last Edit: July 15, 2026, 04:54:04 PM by Tiedie »
Offline dostoy320
« Reply #4 on: July 16, 2026, 08:21:38 AM »
Thank you for the offer Tiedie! Let me see what I can scrounge together locally. My hope is that the rest of my master cylinder components are in good enough shape to be reused.
Offline Tiedie
« Reply #5 on: July 16, 2026, 11:51:35 AM »
No problem. What ever you decide the brakes can be rebuilt all the way to the master to the calipers. Lines and splitter behind the dash.
