Author Topic: Master Fuse  (Read 2256 times)
Offline Kelvin
  • R65LS
Master Fuse
« on: August 17, 2025, 05:20:26 AM »
I've never had a problem with the wiring harness of my R65LS, so I have avoided modification of it on the basis of "if it aint broke don't fix it". I've noticed a number of people to have fitted master fuses or a fuse block and bayonet fuses, but have deferred consideration of same on the basis of not fixing a problem that I don't have.
However, a couple of my friends have recently had problems with melting/combusting electrics. Although I don't want to re-wire the bike I'm thinking that fitting a master fuse in the lead to the positive terminal of the battery would be a good idea, perhaps 25A.
Do other people do this? Is 25A the right size fuse?
TIA
1983 R65LS 1985 to 1988
1983 R65LS 1996 to present.
1983 R65LS 2024 to present.
1984 R65LS 2019 to present.
1985 K75C 2023 to present.
Re: Master Fuse
« Reply #1 on: August 17, 2025, 05:39:41 AM »
The positive battery terminal usually has two cables, a 16mm2 to the starter solenoid to power the starter and a smaller 2.5mm2 cable that feeds everything else. You could fuse the 2.5mm cable at 25A which would be the correct size for that cable.
« Last Edit: August 17, 2025, 05:41:58 AM by Barry »
