Author Topic: Portland Oregon Tech day  (Read 7537 times)
mjbickford
« on: November 26, 2006, 10:39:14 PM »
I must give a big Kudos to all who showed up and helped us (Brett and I) at the tech day.  Yes, you too Ed, thanks for braving the big city traffic.
Especially ORAM Garry Newby, who helped more than most despite, not getting it fixed, and telling me my clutch is toast.  Please don't confuse my constant ribbing, teasing, and banter with ungratefulness.  Dave from Vancouver was a dispensable resource for loaning us tools and knowledge.
Thank you Dave for the help, I would have been lost without you there.
What happened at the tech day, was we pulled two trannies form mid seventies bikes.  Brett's 90s and my 60/5 toaster.  Fortunately for me, there were people there who knew what to do.  While I was messing with my trannie, several others were removing my rear swing-arm, to look for a missing u-joint bolt, clutch, and assembling it all back so I could roll the carcass of a bike around and home.  We did eventually get into the gearbox, and fiddled with it to no avail. At one point, it wouldn't shift at all, but upon reassemble it was back to status quo.  But after sleeping on it for a night, I think the solution is a re adjustment on the1-2 shift fork.  I'll probable go back in and try to fix it at my leisure.  It should be simple, as the retaining nut is eccentric, and right on top.
Symptom:  Bike won't shift into first gear.  Culprit was believed to be an incorrectly index shifter.  We moved it one tooth, which buggered up all the gears, then moved it back to where it was (the correct position.)
Mike Bickford
ABC# 8742
73 R60/6, 81 R65, 82 R65
« Last Edit: November 26, 2006, 11:05:21 PM by mjbickford »
Re: Portland Oregon Tech day
« Reply #1 on: November 26, 2006, 10:48:24 PM »
Hmm, sounds like fun.  One of these days I'm gonna get brave enough to dig into a tranny.  :o I salute you, sir!  [smiley=thumbsup.gif]
« Reply #2 on: November 27, 2006, 12:44:56 AM »
Indeed, you are a braver soul than I, Mike.  Kudos to yourself!
« Reply #3 on: November 27, 2006, 02:15:10 PM »
Sorry Mike, I forgot to get your parts list written down!  I think Gary's little note pad was too small anyway.   :-/  It's good we'll have a tranny expert on the board, at least if the 5 speeds are in any way similar to that 4 speed.
Yeah, I felt so grown up riding through the city and on the interstate, almost as if I wasn't frightened by all the homicidal maniacs.  Sheesh.  At least the deer try to kill you on purpose and are willing to sacrifice themselves to do it.  To the car drivers it would merely be an inconveniance.  It sure was a nice day for a long ride though, sorry you had to drive.
« Last Edit: November 28, 2006, 11:36:30 AM by Ed_Miller »
mjbickford
« Reply #4 on: November 28, 2006, 12:51:21 PM »
no problem, i went to max bmw and set up a phony shopping basket with what I'm pretty sure is everyting.  Printed it out, so all i have to do is find what pile of stuff its in now.
and now that i know how easy(?) it is to remove all the drive bits, im thinking i may eventually repaint/restore the bike.  i was just going to leve it original.
