Author Topic: Rear Shock Adjuster  (Read 916 times)
Rear Shock Adjuster
« on: November 10, 2008, 02:53:54 PM »
Ive noticed in various photos some have the adjuster outside facing forward some inside facing back?? which is correct or does it matter. ive put mine forward for ease of access but i cannot remember which way there were when i stripped the bike
Ta Lou
Re: Rear Shock Adjuster
« Reply #1 on: November 10, 2008, 04:09:38 PM »
I believe 'forward' is the lightest of SPRING PRELOAD setting, which is what this handle is for.
With the handle 'rearward', the springs will be at their stiffest, and least comfortable, but better able to handle heavy loads.
But the bottom line?
If you still have these shocks on youe bike, you need to replace them.  They were marginal at best, when they left the factory.
Do a search in this section for "shocks", and you find plenty of suggestions for replacements.
« Reply #2 on: November 10, 2008, 08:19:49 PM »
On my particular bike the handles faced inward. Possibly to avoid interference with the  factory luggage, passengers legs? I've since replaced the factory shocks with aftermarket units which have a tool, instead of the handle, for adjustment.
« Last Edit: November 10, 2008, 08:20:17 PM by MrRiden »
« Reply #3 on: November 14, 2008, 08:47:15 PM »
