Author Topic: R65 decal source?  (Read 1825 times)
Allred
R65 decal source?
« on: October 31, 2008, 05:27:04 PM »
Wow! online price at Max's BMW for the original styled "r65" decals that go on the side covers is up to $18 each!    :o
I need two, in white for Chica-tita.  Anyone know of a more reasonable priced source?  If not, I suppose I'll look into the local sign/decal shop to see if they can make me up a couple.
Thanks,
Re: R65 decal source?
« Reply #1 on: October 31, 2008, 05:50:03 PM »
I'm halfway, or less, considering adding the R65 logos to my freshened side panels, too. perhaps a brushed aluminum color to match the engine cases?
Having owned/operated a sign graphics business for a number of years, I'd suggest you visit your local "brother of the brush". The R65 logo font is quite common and you'll have a myriad of color choices. Should be way less expensive, too.
If you elect to go this way, I can show you a couple tricks to get the logos placed properly, eliminate bubbles and avoid being just a tad off plumb. It's my job, man.
« Reply #2 on: October 31, 2008, 07:19:39 PM »
That's the way I went for my later model "Mono" style decals.  Only took a couple of days.  I ordered four in BMW blue, so I could keep a set in case I have my bike repainted in the future.  Cost $32 including tax.
(I think they had a minimum order of $25)
Ed
« Last Edit: October 31, 2008, 07:20:34 PM by not-so-fast-ed »
aussie
« Reply #3 on: October 31, 2008, 07:30:48 PM »
I got mine on eBay from Austria - ID is lazygirly - she's fast an efficient. I think from memory they cost about $A32 for the pair including shipping. (Why is shipping sooooooooooo expensive from Europe??  :()
Another company I found has the attached link:
http://www.ihearyasureyado.com/store/category.php?manufacturer_id=46&category_id=65
They're based in the US and have a variety of colours and sizes.
They start at $US8.25
For all that - I think I'd go with Monte's suggestion.
« Last Edit: October 31, 2008, 07:31:52 PM by aussie »
larstorders
« Reply #4 on: November 01, 2008, 02:09:11 PM »
They ain't the easiest to stick on. Beware, very very stiicky, they jump off the backing all by themselves and stick in the wrong place and then when you try to move them they tear.  >:( >:( Aaargh.
I'd say if a sticky stencil of  the R65 logo could be made, a rattle can spray job would produce an equally good , or even better result. (I've done quite a bit of rattle can spraying recently).
I saved the backing from my last R65 stickers so I can use a stencil n spray if I need to do them again  8-)
« Last Edit: November 01, 2008, 02:10:03 PM by larstorders »
« Reply #5 on: November 01, 2008, 03:03:46 PM »
There's a very simple way to avoid the "static cling" issue, air bubbles, misalignment and assorted evils when applying vinyl graphics...   small drum roll, please...
To one quart of water in a spray bottle, add one drop - no more - of liquid dish washing detergent. We now have a wetter/sticker solution.
Before peeling off the hard paper backing and with a light touch, draw a pencil baseline at the bottom of the graphic. Place a couple of bits of masking tape in the area of the planned application area and draw the correct horizontal alignment to use as a guide for application.
Remove the hard paper backing and lightly mist the vinyl adhesive. Don't soak it, just a light mist.
Place the graphic in position. You may then slide it around to match up with the guide-on marks.
A rubber squeegee or similar is then used to gently work the vinyl onto the substrate. Working from the center outward, squeegee all the water and air bubbles to the edge of the vinyl and away. Do not remove the carrier strip until dry. Then remove the carrier strip by pulling it parallel to the surface of the graphic. Watch corners and 'sharps'. If the vinyl wants to lift, stop and wait awhile.
Never puncture the vinyl to release trapped air. Again, wait. 99 outta 100 times, the air bubble will disappear all by itself. Patience.
That's the trick for successful vinyl graphics applications.  Have fun with it.
« Last Edit: November 02, 2008, 08:58:06 AM by montmil »
« Reply #6 on: November 01, 2008, 05:40:45 PM »
I just got these from my local BMW dealer on the credit I have there (from my gift certificate from work).  I will scan them into my computer.  Then we'll have the graphic available.  Mine are white, but I'm sure I can figure out how to get a good scan.
Monte, thanks for the tricks for putting these on.
larstorders
« Reply #7 on: November 02, 2008, 05:13:33 AM »
Thanks for those instructions montmil. I'm sure they'll save a lot of frustration for some of us.
But, crickey, for the price they charge  they should supply instructions with the decals  >:(
« Reply #8 on: November 03, 2008, 01:39:15 AM »
Aw come on!
 http://www.google.com/search?client=firefox-a&rls=org.mozilla%3Aen-US%3Aofficial&channel=s&hl=en&q=how+to+apply+decals&btnG=Google+Search
« Reply #9 on: November 03, 2008, 01:56:49 PM »
The procedure Monte outlined (I personally use the solution to liberally wet the surface I am applying to) holds true to ANY adhesive transfer/film/whatever.   This is also how window tint film is installed...
« Last Edit: November 03, 2008, 01:58:39 PM by admin »
