Author Topic: Windshield For My 79 R65  (Read 1906 times)
Eaglemedic
« on: October 16, 2008, 09:19:07 PM »
I am trying to find out if I can fit a windshield for my 1979 R65.  The bike is stock, the bars are short and the rubber dash cover leaves no room for a bar mounted windshield.  Have any of you guys figured it out or have any suggestions?
« Last Edit: October 16, 2008, 09:21:02 PM by Eaglemedic »
drewboid
Re: Windshield For My 79 R65
« Reply #1 on: October 17, 2008, 08:06:30 AM »
The National Cycle Street Shield worked for me on my 1984. JCWhitney says it will work on a 1979 model. I've been happy with it. they also make larger and smaller models.
Eaglemedic
« Reply #2 on: October 18, 2008, 10:36:09 PM »
Thank you for responding Drew.  Good suggestion, I may try the Street Shield or Street Shield EX.  I attached a pic of my bars showing little real estate.  Do you think it will mount or will I have to use a razor blade (only kidding).
« Reply #3 on: October 19, 2008, 11:07:58 PM »
Looks like you have clipons...much smaller than mine!  There are some headlight mounted screens that might work for you.  Givi makes one that I have on mine as well as a little S-type screen that JC Whitney sells.  They were both mounted using the headlight brackets, so not having room on the bar matters.
There have been a couple of threads on windshields lately.  Do a search and you should find lots more discussion of this.
drewboid
« Reply #4 on: October 20, 2008, 07:34:38 AM »
Not much room there at all! I can't tell but if you have about 1 1/2 inches of straight bar available you MIGHT make them fit. I don't see space between the dash panel and the brake MC though.
Perhaps the headlight ear mounted ones would work but I have no experience with them.
DgM
« Reply #5 on: October 20, 2008, 11:54:11 AM »
I have a Manxman fairing on my R65, I have narrow bars, no issues with clearances.
Check out:  http://www.bikescreen.com/categories.asp
type Manxman in search, see manxman 65 with standard and 'spoiler' windscreens.
« Reply #6 on: October 20, 2008, 06:53:53 PM »
I have the same handlebar as you do, E.m.
I bought a 2nd dash and cut it up when I tried mounting a windshield.
You can have it, if you want.
click for larger image
Eaglemedic
« Reply #7 on: October 21, 2008, 11:36:12 AM »
Rob, thank you, I will take you up on your offer.  I think that is a simple solution to my problem.  I sent you an email.  John
Crossrodes
« Reply #8 on: October 24, 2008, 12:20:53 AM »
I put a Givi A750 on my '79.  It attaches to the headlight studs.
http://www.givi.ca/en/pb_carenage.php
Mike
Jon_P
« Reply #9 on: October 24, 2008, 07:48:24 AM »
i had the A760 givi on mine and liked it, i also had it on another bike that had little room on the bars and was able to get it to fit.
