Author Topic: Deltran Battery Tender Junior  (Read 2332 times)
« on: November 24, 2019, 02:08:19 PM »
Received an advertisement in the mail last week for a national hardware store chain, Tru Value, they have the Battery Tender Junior on sale for $20 .
Don't know if this is nationwide or just local to me .
My battery maintainers have been giving me problems for about 6 months, won't shut off on motorcycle batteries, work great on auto batteries though .
« Last Edit: November 24, 2019, 02:19:32 PM by Bob_Roller »
Re: Deltran Battery Tender Junior
« Reply #1 on: December 02, 2019, 10:38:22 PM »
I have a "Jr" and a dual station Battery Tender and both work great.  That's an excellent price for a "real" Deltran tender.
Offline dogshome
« Reply #2 on: December 23, 2019, 06:52:14 AM »
I have a small 3A intelligent charger which is safe and works with most things I've had and does work on the R65 but! The regulator on the bike is connected at all times and will stop the charger from reaching peak (a bit higher than float voltage). So disconnect battery if using man-size charger.
« Reply #3 on: December 23, 2019, 09:59:00 AM »
I'm thinking this has to be a non standard set up as the ignition switch would normally isolate the VR from the battery.  Does the battery not run down via the charge light (if there is one) without an ignition switch isolating the charging circuit
« Last Edit: December 23, 2019, 10:00:03 AM by bhodgson »
Offline skippyc
« Reply #4 on: December 23, 2019, 04:50:42 PM »
The regulator supplies current to the alternator armature only. It is activated by the power from the ignition light. It can't affect the charger on the battery.
Offline dogshome
« Reply #5 on: December 29, 2019, 12:07:28 PM »
Interesting. The bike is charging properly and not discharging, but I've never seen my smart charger be cut off, suddenly drop and then start to build voltage again.
Looking at the diagram, I'm not sure how the regulator could affect the battery voltage directly either! That is if all the diodes are OK.
