Author Topic: Carb o rings  (Read 729 times)
Offline BooG
Carb o rings
« on: October 08, 2008, 08:21:36 AM »
When installing new carb o rings, do people put them on dry, or with some sort of grease?
Ta!
BMW R65 1980.
Vespa Sprint Veloce 1971
BMW K75S 1987
Re: Carb o rings
« Reply #1 on: October 08, 2008, 09:21:30 AM »
I would lightly lubricate them.  I have used silicone based oils/greases, motor oil, etc.
Allred
Re: Carb o rings
« Reply #2 on: October 08, 2008, 11:01:05 AM »
+1 on the lube.  I used vaseline when I rebuilt carbs on Chica-tita last June.
Lube is particularly helpful when rolling the "O" rings over the head/threads of idle needle and needle jet holder, etc.  Helps them slide into place with less chance of catching or tearing during installation.   After the rings are in the proper space, wipe off any excess lube.
Works for me.
