Author Topic: Leaking Left Carb  (Read 859 times)
joshr65
Leaking Left Carb
« on: October 05, 2008, 11:46:04 PM »
When bike is not running and petcock is open. Stops when I turn off fuel. I guess bad float valve or sticking pin? Any advice before I open up? Or just leave as is and remember to turn off fuel?
Thanks!
Josh
vestandpants
Re: Leaking Left Carb
« Reply #1 on: October 06, 2008, 01:44:46 AM »
its a problem ive had before. firstly the float has to be set up properly, and secondly the carb has to be level, if it is inclined towards the block it will disturb the float and leak.
see: http://www.cdegroot.com/cgi-bin/mirror/pweb.jps.net/~snowbum/bingcv.htm
and lastly, I turn off the fuel just to be safe  ;D
« Reply #2 on: October 06, 2008, 07:27:17 AM »
...plus the float pivot pin could be binding, the floats could be "gas-logged", the float needle seat could have crap in it from a deteriorating fuel line, and/or the float needle could be shot.  Bing advised me that the actual seat would be the last suspect as seats in carbs with rubber tipped needles will last virtually for ever.
« Reply #3 on: October 06, 2008, 07:01:53 PM »
That's what I really like about this lash up... Gotta problem? Lottsa experienced folk willing to assist.
Good on ya, guys!
joshr65
« Reply #4 on: October 06, 2008, 10:12:42 PM »
Yes Sir ! Thanks for the advice. Will take that float bowl off and see whats going on!
 :D
