Author Topic: Slow to lose revs  (Read 2158 times)
plc
Re: Slow to lose revs
« Reply #15 on: June 29, 2008, 07:21:33 AM »
Hi Guys,
Well on Friday I removed the beancan from the bike, opened the little port and checked out the weights.  Now I have nothing to compare with having never seen them before, but they appeared pretty clean, opened with little force and flicked back fairly well when I let them go. The springs looked pretty good too. Added some light oil to the pivots, cleaned up the case and refitted the bean can.  Timing appears OK, so I am borrowing a timing light tomorrow. The bike idled fine and rode like before.
No real clear indication of slow rev loss but it was quite a short ride.  I will give a full update of my progress after tomorrow's longer ride.
Once again thanks for all the advice.
Best to all,
Paul
plc
« Reply #16 on: October 01, 2008, 01:21:42 AM »
Hi All,
Just wanted to let you all know the slow loss of revs problem is fixed. I took the bike to a good bike mechanic, he told mew the fault was not unknown to him.  He replaced a leaking inlet manifold and overhauled the carbs and retuned the bike.  The bike now idles well and I have engine braking now.
Mind you when I picked it up my gear changes were  really rough since the revs dropped away as they are supposed to on each change.
Just thought I would let you all know the outcome in case the same thing happens to another R65 newbie like me.
Take care,
Paul
« Reply #17 on: October 01, 2008, 04:04:10 AM »
As the original poster's issue was solved, Trolle's issue has been moved to [link=http://suraklyn.com/yabb/YaBB.pl?num=1222851851]This Thread[/link]
« Last Edit: October 01, 2008, 02:40:25 PM by admin »
