Author Topic: 100/90 Front Tire on 1.85 Rim?  (Read 1709 times)
bobbydyabb
« on: January 10, 2010, 03:27:21 AM »
Browsing the archives, many of you appear to use a 100/90-18 front tire.  Am particularly interested in this size as it is very close in diameter to OE 3.25x18.  Problem is that some tire makers, (Avon & Bridgestone and maybe more), specify a minimum applicable rim size of 2.15 for this size (my ' 83 R65 OE front rim is 1.85).
So, if you're using this tire size on a 1.85 rim, may I ask what your real world experience is?  Brand of tire, tire pressure used, turn in and cornering characteristics, straight tracking?
Thanks,
Bob Dominguez
'83 R65
Cerritos, CA
Re: 100/90 Front Tire on 1.85 Rim?
« Reply #1 on: January 10, 2010, 07:05:21 AM »
I've been using the 100/90x18  front tires ever since I replaced the OEM Continental tires in 1987, no issues yet .
A recent poll, showed three favorites of the members here, Bridgestone Battleax, Metzeler Lasertec, and Michelin Macadam .
Pressures in the 35 psi range seem to be about the normal pressures run in these tires .
I've been using the Metzeler Lasertec tires, formally the ME33/ME99 tires .
They are not the longest life tire, I get about 11-13,000 miles on a front, and 8-10,000 miles on a rear .
Last set I had put on was $350, that included tires,tubes,mounting and balancing the obligatory taxes and tire disposal fees .
I don't get to ride in too much wet weather here in Phoenix, but the few times I have, the tires didn't give me any problems riding in wet conditions .
But they stick like 'velcro' once warmed up .
« Last Edit: January 10, 2010, 07:15:21 AM by Bob_Roller »
« Reply #2 on: January 10, 2010, 09:33:53 AM »
My R65's, 81 and 83, roll on 100/90x18 fronts. Bridstone Spitfires on the '81 and Avons on the '83; not my choice, fresh ones came on the bike. Playing with tire pressures between 31-35psi.
I'm no Matt Mladin but I have enjoyed bending both brands.
« Reply #3 on: January 14, 2010, 04:51:10 PM »
You will have no problems using the 100/90-18 tire on the 1.85 rim.
BTW - I just replaced the whole front end with a 1988 K100RS front end with a tubless 2.50X18 rim.  Works great on my 1980 R65 so far.  I got an unbelievable deal on the complete front end off ebay.  Funny thing is it came with a good 100/90V18 BT45 tire!!
It is nice to have the right sized rim for the tires involved.
