Author Topic: Dreaded tire thread moved from Tech...  (Read 3235 times)
CC_Vic
« on: July 01, 2007, 10:43:00 PM »
I'm replacing the ancient (ME 33 Laser; made in Germany) Metzlers on my '80 and am considering all options.
Any recommendations would be appreciated.
Thanks in advance
« Last Edit: July 02, 2007, 10:40:24 AM by CC_Vic »
Re: Dreaded tire thread moved from Tech...
« Reply #1 on: July 02, 2007, 10:43:22 AM »
We had this thread a few months ago in which many talked about their choice in tires:
http://suraklyn.com/yabb/YaBB.pl?num=1177033059/12#12
Hope that this helps !
CC_Vic
« Reply #2 on: July 02, 2007, 09:38:38 PM »
Very very helpful-Thanks!
freebie79
« Reply #3 on: July 03, 2007, 10:39:23 PM »
i just put on bridgestone spitfire tires  100/90 front and 110/90 rear on my bike and i love the road holding ability of the tires. and there pretty good with rain grooves in the freeway too. note i have very limited bike tire experience. but I've seen them recommended else where for our older bikes hope this helps
« Reply #4 on: July 03, 2007, 11:39:31 PM »
You need to decide for yourself what tire best suits your needs as everybody rides differently and is after different things.  If you ask the collective for suggestions you need to describe your riding style and what you expect from a tire.
This is one of the few forums that will tolerate a tire thread (go start a tire thread over at boxerworks and see what happens...), but if they get out of hand I move them to the "Off-Topic" section.
« Reply #5 on: July 04, 2007, 12:59:52 PM »
I've had Metzelers on the R65 since '87 or '88, and they are a good tire, but don't feel quite right in wet conditions, but with living in Phoenix that's not much of a problem. The tires need to warm up before you ask too much of them, as I ride all year long, temps in the 30's F. will give you a real 'slick' tire for a couple of miles. Average mileage for the Lasertec's are about 8-9,000 miles for a rear and 12-13,000 miles for a front. At least that has been my experience.
CC_Vic
« Reply #6 on: July 04, 2007, 02:01:17 PM »
Thanks for the info; I ride 9-10 months a year and live in the northeast.
I avoid rain when I can but it rains alot in the fall and I need to be ready.
Lots of great twisty mountain roads in our area and I'm happy at 65 mph on the parkways.
« Last Edit: July 04, 2007, 02:03:48 PM by CC_Vic »
Clutch
« Reply #7 on: February 27, 2009, 10:50:36 AM »
hey everyone,
I haven't been back to this site in some time, and the link nhmaf gives above doesn't seem to work anymore.  I also seem to have trouble finding this information by doing a search on the word "tire".  Can anyone else find this forum thread easily?
Also, I'm pondering putting some tube-type tires on my 81 r65, because the last tires (tubeless) I put on were absolutely a bear to get on, and there would be no way for me to fix a flat on the roadside because the bead would be too hard to deal with.  Luckily I didn't have a flat with these tires.  Am I correct in presuming that the tube-type tires' beads are easier to deal with?
thanks!
larstorders
« Reply #8 on: February 27, 2009, 12:34:41 PM »
I like Bridgestone BT45 s. Good in the wet and the dry. Getting about 7500k from the rear, high speed mway cruising and abrasive mountain road scratching. Gotta be a 100/90 up front cos the sizes are a bit skinny compared with other manufacturers tyres. If the wheels and tyres are nice and warm they can be fitted more easily. A good lube is very helpful too.
« Reply #9 on: February 27, 2009, 12:41:17 PM »
nhmaf's link tries to take you back to the 'old' domain that no longer has the forum on it. So...I tried the search as well and it looks like the search is only working on the new threads since the upgrade?  Yes, I went to advanced search and changed the time frame to all posts instead of just a week.  It only returned 9 finds, even with a limit of 15 - all of which were this particular thread.
Must be another glitch with the move?
So what's up? ------Oh, I got it, that was way back in 2007...duh!
« Last Edit: February 27, 2009, 12:42:26 PM by msbuck »
drewboid
« Reply #10 on: February 27, 2009, 12:54:43 PM »
Check out:
http://www.webbikeworld.com/Motorcycle-tires/sizes.htm
They recommend the BT45 in 110/80-18 for the front. That's what I have and find them great.  YMMV
steve_wicks
« Reply #11 on: February 27, 2009, 04:03:46 PM »
I've got Kenda - front 90/90 & rear 110/90 but I need a new rear tyre from was put on by previous owner about 1000km ago.
Do I like them?  ....... dunno, maybe a new rear will make the bike feel better!
« Reply #12 on: February 27, 2009, 04:29:09 PM »
Sometimes ya just gotta do a little hand-editing in these cases where the fancy-schmancy URL gets broken, I think that this link here will take you to the old thread, now hidden in the bowels of the new forum....
bwahahahahahaha !
http://www.bmwr65.org/cgi-bin/yabb2/YaBB.pl?num=1177033059/12#12
« Reply #13 on: February 27, 2009, 05:56:20 PM »
bwahahahahahaha !
OK, I tried hand editing, but didn't relaize I needed the /cgi-bin/ in the middle.  It works now!  Thanks nhmaf.
« Reply #14 on: February 27, 2009, 06:14:32 PM »
I don't think they make "tube-type" tires for motorcycles, anymore.
We just put tubes in our tubeless tires.
When you are trying to get the last bead over the rim, go to the opposite side of the wheel, grab the tire and squeeze the two beads together and shove them as deep as you can into the channel that runs around the center of the wheel.  That will give you a little more room on the other side, where you are trying to get the bead over.
