Author Topic: SPOT. The World's First Satellite Messenger.  (Read 1024 times)
« on: June 16, 2008, 03:17:06 PM »
http://www.findmespot.com/Home.aspx
A few of us were sitting around the campground on Saturday discussing the lack of cell phone coverage and worried family members back at home.  This is the Personal Satellite Tracker we talked about.  Just wanted to pass along the info for those interested.  Seems like a mighty fine idea to me.
Re: SPOT. The World's First Satellite Messenger.
« Reply #1 on: June 16, 2008, 07:24:58 PM »
Communication technology. If it saves one individual's life, it's worth it.
     Besides messing with motorcycles, hot rods and airplanes, I'm also a rated pilot serving in the United States Air Force Auxiliary Civil Air Patrol. Many of our emergency missions are for missing and/or downed private aircraft.
     Most, but not all, of these aircraft are equipped with an Emergency Locator Transmitter (ELT). The ELT is designed and installed so as to be activated upon impact. Often, just a hard landing will trigger the signal.
Aircraft ELTs transmit on 121.5 MHz or 243.0 MHz as do the EPIRBs.
ELTs (Emergency Locator Transmitter) signal aircraft distress.
EPIRBs (Emergency Position Indicating Radio Beacon) signal maritime distress. Often, these are attached to individual flotation devices or life rafts.
PLBs (Personal Locator Beacons) On 406 MHZ, are for personal use and are intended to indicate a person in distress who is away from normal emergency services such as 911.
     In the case of the PLB 406 MHz beacons, which transmit digital signals, the beacons can be uniquely identified almost instantly (via the GEOSAR satellite), and furthermore, a GPS position can be encoded into the signal thereby providing both instantaneous identification of the individual along with an emergency contact telephone number and the individual’s position.
The basic purpose of all distress radio beacons is to get people rescued.
     By 01 February 2009, the 121.5 and 243.0 MHz ELTs and EPIRBS will no longer be detected by the SARSAT (Search and Rescue) satellites although some ground stations may still monitor the frequency for a period of time.
Fly safe.
Monte Miller, Major
USAFAux
Chris_in_BC
« Reply #2 on: June 17, 2008, 12:18:40 AM »
The boss in my family bought one for me as  I have a tendency to ride solo in the 'bush' quite frequently and offroad down in Mexico each year. There is a yearly service charge but like everything, if you never need it, it will be a waste of money, but like all insurance you only have to make use of it that one time!  :-[
The following is an 'OK' message sent after I came back to pavement. I am still experimenting with it.
SPOT Check OK.  Everything is going fine.
ESN:0-7383456
Latitude:50.47
Longitude:-119.355
Nearest Location: Glenemma, Canada
Distance: 0 km(s)
Time:06/15/2008 16:41:58 (America/Vancouver)
http://maps.google.com/maps?f=q&hl=en&geocode=&q=50.47,-119.355&ie=UTF8&z=12&om=1
« Last Edit: June 17, 2008, 12:21:32 AM by Chris_in_BC »
