Author Topic: Good Luck or Bad Luck  (Read 2610 times)
« on: May 23, 2008, 11:07:05 PM »
Thursday night I was in the bathroom (downstairs, of course) and I heard a sudden sound like water going on full force.  Oh god!  What now?  Is someone using my water outside?  No.  I knew I didn't have any water on anywhere, but the washer had been on earlier.  Okay, upstairs I go, slowly because of the cast on my foot.  It's coming from the bathroom.   :-?
I see a wet area on the carpet by the bathroom door.  I hop in and it is squishy, splashy wet.  Oh no!  I get to the bathroom and turn on the light.  Water is pouring out of the hose going into the toilet.  Okay, I can stop this fast by turning that off.  But I have to step in on my right foot to get into the bathroom,  The water is about 1" deep.  One quick  step on my cast will be okay.    I get my knee up on the toilet seat with my left foot in the water and get the water turned off.
Then I look around.  What a mess!  I gotta get this water off the floor before it leaks through.  So I empty the bucket of the tools (from the work I was doing up there earlier this year) and start scooping.  I scoop and scoop and scoop some more until there isn't enough to scoop.  Then I take some big sponges I have up there and start sopping up the water and filling the bucket that way.  All  this bending is tiring.  But I can't kneel on  the floor until I get a big enough dry spot where I can put my leg with the cast, which I finally do.   I end up getting the cast a little bit wet at the toe which I dry out with the hair dryer.
I finally get the floor dry, even with the backflow of water from the carpet.  Now to tackle the carpet.  It is soaked.  But I'm able to move a few things out of the way enough to get the whole wet part cleared off.  I try to sponge it up, but it's like sponging from a sponge.  I finally get as much done as I'm going to.  Then I put the fan on to see how much it will blow dry over night.
Next plumbing to do is replace the hoses and connections on both toilets!  And check the hose on the washer!!!!!  Within the month!
I had help getting a wet vac and a dehumidifier to try to dry the carpet out.   I did have help getting the carpet wet vac'd.  And I did more later.  But I don't know if it's working.  This is a mess and hard to take care of with 2 good legs much less with one in a cast.
I was getting very disgruntled and feeling really bad about this.  Then I realized that if I didn't have a cast on my leg I would have been gone this weekend to the 49er Rally.  If this had haappened while I was gone for an extended weekend, that water would have been spurting out for days instead of minutes and the water would have flowed through the whole upstairs and then through the whole downstairs before anyone would have noticed it flowing out the doors.
So, I ask you, am I lucky or what?   :o
Re: Good Luck or Bad Luck
« Reply #1 on: May 23, 2008, 11:17:53 PM »
I should come up with a clever saying, along the lines of "'With luck like that,...." but I don't know what to add.  Sorry, no imagination.  Sometimes I think internal plumbing was a big mistake, and yes I have lived without it.  Not in Alaska or anything like my mom, but here in Oregon.
I'm impressed that you were able to deal so well with the situation, especially considering that hunk of plaster you're dragging around.
Think you can make it to Chief Joseph?
I ask, even though I myself am not really committed to it yet.  Sigh.
« Reply #2 on: May 24, 2008, 02:17:44 AM »
I would have had a nervous breakdown, for sure.  You are a gem, Melena!
I wish I lived near by so I could have helped our friend.
You are not letting this 2nd cast slow you down much, it appears.
Is this place like a condominium?  If it's not too personal.
« Reply #3 on: May 24, 2008, 09:57:53 AM »
I once saw a home where the washer hose broke and filled the basement like a large swimming pool. Ever since then I always shut down the water heater & then the water to the house when away for more than a day. You lucked out tho I'm sure you might not feel too lucky at the moment!
« Reply #4 on: May 24, 2008, 10:34:07 AM »
WHATTA WOMAN!!!      [smiley=thumbsup.gif]
You're our hero Melena.
Very sorry for your misfortune and really admire your "take charge" attitude in handling it.
Told my wife about it and we agreed to start turning off the whole house shut off valve when we leave on trips.  Won't handle daily water crises, but at least give us one less thing to worry about when we're out of town.
Best,
Ed
« Last Edit: May 24, 2008, 10:35:48 AM by not-so-fast-ed »
« Reply #5 on: May 24, 2008, 07:53:54 PM »
Good job, Melena !
The last time something like this happened to us, we were away on a 10 day trip to Costa Rica during the middle of
winter.   When we returned, I soon realized that there was not heat in 1/2 of the house (hot water heat).   I discovered that
we had a couple pipes freeze in an outer wall (the temperature had been down to around -50 for several days, and we had foolishly
turned the heat down in our house since we were going to be away).  Fortunately the pipes really froze and did not thaw out, so
that even though they had split and would have filled the basement with water over the week or more that we were gone, the ice "plugs"
held the water in, and I only had to clean up a few gallons of water in the carpet and replace a couple square feet of sheetrock, after
the plumber came in and replaced several feet of pipe.
I also thought, man, why did this happen while we were gone ?!  And then I thought, man, we were VERY VERY lucky that it wasn't
a whole lot worse !!!!
« Reply #6 on: May 24, 2008, 10:37:55 PM »
Thanks for the kind words.  But I just do what has to be done.  I'm a practical person in that way.  No one else around to do it.  And this is my own place - I'm not renting.  You'e right, Rob, it is a condo.  It's only about 890 sq ft.  1 bed and bath upstairs and one bed and bath downstairs.  I've been trying to make the upstairs a craft/work room, but it's ended up being a "what do I do with this - oh just put it upstairs for now" storage room (sigh).
The carpet is dry, and the padding under it is almost dry.  It will be by tomorrow.  But the carpet is old and even though it was in pretty good shape before, all the water discolored it and it will have to be replaced.  That was in the plans anyway, but now it will just happen sooner.  And I'll have to get rid of all the junk!   ;D  It's good to lighten the load now and again.
« Last Edit: May 24, 2008, 10:39:02 PM by Melena »
« Reply #7 on: May 25, 2008, 08:13:04 PM »
Melena, usually your home-owners policy will take care of this.  I know last time our water-heater bit the dust we got the carpeting replaced in the whole house and then about a year later got a check for our deduct as they went back on the water heater mfg. and made them pay...
« Reply #8 on: May 26, 2008, 10:55:10 AM »
... I get my knee up on the toilet seat with my left foot in the water and get the water turned off...
Thank goodness your local plumbing code required cut-offs at the toilet. Probably have them at all water service lines. I can remember when there was no such code here in Texas... when something like a toilet started to overflow, everyone tried to remember where the water meter cutoff was... outside! "Say, Honey, isn't the meter under your rose bush garden?"
Got a buddy at work who lives in an older home and isn't as handy as you. He wanted to pay a plumber to install his new kitchen sink and the plumber was required to bring his water service up to code. Turned out to be a rather expensive sink!
I wonder why so many guys - but not us R65ers, of course - are surprised that a woman can handle "manly" chores. D'oh. I'm on a VW Cabriolet group forum where several women can turn their own wrenches with the guys on these labor intensive cars.
You go, girl! Heal up.
Happy Memorial Day.  Monte
« Reply #9 on: May 27, 2008, 09:37:01 PM »
Way to go Melena!  Sad to hear you had to deal with it in the first place.  The one time something like that happened to me....
It was my duplex neighbor's sink pipe that broke.  She comes over looking for help just as the water starts seeping though the common wall into my closet.  We had the "the turn off is out on the street" issue, and the landlord had the necessary equipment to make that happen.  Unfortunately, he was miles away and we had to WAIT!!!   :o
I had a class that evening and my WONDERFUL, MARVELOUS, AMAZING husband (to be, at that point) said, "You go on to class and I'll handle this."  UNBELIEVABLE!  He was my hero that night as it turned into a real mess - invading three rooms of my small duplex - including a 'storage' room somewhat like your upstairs.
I came home to a (mostly)dry home and a tired, grumpy exasperated sweetheart... that's why I love him!  :D
« Reply #10 on: May 29, 2008, 07:07:23 PM »
Thanks for the insurance advice Justin.  I don't know why I didn't think of that one myself.
I called the insurance company and the adjuster called me back and gave me some places to call.  One of them I had dealt with at work and didn't like them so I called the other one.  They called me back within 1/2 hour and were out here within a couple hours.  They were fast!  They checked for water and found it under the vinyl in the bathroom.  I hadn't even thought about that.  Also, there was still water under the carpet padding further up than I had realized.  Had to pull up the vinyl and the underlayment that was wet and the padding under the carpet and put in another dehumidifier to get rid of the rest of the water.  The insurance will cover all but $500 (my deductible) of the $1500 to $2500 to take care of the mess and put new flooring in the bathroom.  The carpet will be okay - just will need new padding in the water damaged area and a cleaning.
So, a lesson to be learned here.  Always call the insurance company and see what they will take care of before doing anything else.
« Reply #11 on: June 02, 2008, 08:46:56 AM »
Melena, glad you got some help from them!
trolle
« Reply #12 on: June 03, 2008, 02:44:11 AM »
As my grandfather always said: Don't be too sure, be insure(d), but then he was in the insurance business.
Good to hear that your misfortune has had an almost happy end.
greetings from a north with drought - the sun has been shining from a clear sky for 33 days in a row, the meteorologists are thrilled because they have a new record in sun hours for the month of May and everything is so dried up, that a general ban on open fire has been issued.
trolle
« Reply #13 on: June 03, 2008, 01:08:37 PM »
trolle
So they are giving the little boy at the dike a few days off?
« Last Edit: June 03, 2008, 01:08:48 PM by Rob_Valdez_79_R65 »
