Author Topic: Electrical connector source?  (Read 3065 times)
Offline DeeG
« on: October 21, 2017, 09:47:21 PM »
Anyone know of a source for this style electrical connector? Its the one that goes from the main harness to the transmission switch.
I'm going to get the transmission switch part of it, but the male part on the main harness is toast. The plastic housing is bubbled away.  Looks like the P/O (or someone) spilled battery acid on it, and 'fixed' it by wrapping it in electrical tape.
I've combed the on line catalogs and dealer fiches, but in order to get just that connector, I have to buy a new main harness. I'd rather not use something more modern if I can find something that looks (or is) original.
Thanks!
Dee G
1978 R45/N ?
1978 R80 w/hack
1971 R75 (swb)
Re: Electrical connector source?
« Reply #1 on: October 21, 2017, 11:36:07 PM »
You might have to replace both with a matching pair...
Offline BPT
« Reply #2 on: October 22, 2017, 12:43:56 PM »
Have you tried to call Max BMW? Or maybe someone like EME?  The people at Max have been somewhat helpful with me in trying to find things like that. Not necessarily successful but they've been happy to look.
Ditto with the CycleTerminal guy. He was very responsive to my emails.
I ended up finding a perfect match to the BMW dash switch connectors at Mouser. Their site can be a royal pain in the ass to search but they have tons of stuff.
« Reply #3 on: October 22, 2017, 01:29:41 PM »
Here's two pages from RealOEM.com , they have what looks like both sides of a similar connector .
http://www.realoem.com/bmw/enUS/showparts?id=0364-USA-09-1980-248-BMW-R65&diagId=61_0200
http://www.realoem.com/bmw/enUS/showparts?id=0364-USA-09-1980-248-BMW-R65&diagId=61_0199
Item 7 on the first link, item 11 on the second .
Don't know if they even available anymore .
I think I would be inclined to use common spade type connectors and put heat shrink on the connectors to keep them from coming apart .
« Last Edit: October 22, 2017, 01:34:16 PM by Bob_Roller »
Offline DeeG
« Reply #4 on: October 23, 2017, 12:45:49 PM »
 I tried contacting Max.  Emailed them about three weeks ago, but haven't heard back yet.  And how the heck did my late night, exhaustive searches not turn up Cycle Terminal?  Their two pin connector looks about as close as I'm gonna get.  woo hooo!!
THANK YOU ALL!!!
Now to order up some stock looking wire.
Dee G
1978 R45/N ?
1978 R80 w/hack
1971 R75 (swb)
Offline BPT
« Reply #5 on: October 23, 2017, 05:10:49 PM »
Glad you found a fix. There are a few sources for "proper" wire (colors, stripes, etc.) or else you can just go with good quality but close-enough color-wise.
With Max, I've always called. And if it's anything that's exclusive to anything remotely "old", they'll put you to one or two guys there.  As I said above, I haven't always been successful but they've been happy to talk with me and do some digging. Or save me some digging by telling me if they know for sure they don't have something, can't buy it separately, etc.
I hope you'll report back with the excellent results of your fix.   [ch128512]
« Last Edit: October 23, 2017, 05:21:13 PM by BPT »
Offline BPT
« Reply #6 on: October 27, 2017, 06:05:09 PM »
Hey DeeG - maybe you've figured it out already but I stumbled upon this page on Eastern Beaver.  I discovered that Powerlet connectors use a T.  Not sure if the size or orientation is the exact same but this looks close?  Or maybe these are the same as what you already found at CycleTerminal?
https://easternbeaver.com/Main/Elec__Products/Connectors/250_Connectors/250_connectors.html
Offline DeeG
« Reply #7 on: November 04, 2017, 10:29:31 AM »
I had completely forgotten about Eastern Beaver.  They have lots of stuff there.  :-)
Dee G
1978 R45/N ?
1978 R80 w/hack
1971 R75 (swb)
