Author Topic: Adjustable heel-toe shifter - Release Version  (Read 1305 times)
« on: August 18, 2008, 07:23:14 AM »
I have made my tweaks and this is what I have came up with:
mikethebike
Re: Adjustable heel-toe shifter - Release Version
« Reply #1 on: August 18, 2008, 08:51:41 AM »
A good looking piece of kit Justin.  Well done you.  :)
« Reply #2 on: August 18, 2008, 08:36:54 PM »
Very nice, Justin!
I think of you often, nowadays, as I ride along with my feet on the passenger pegs...  ;)
« Reply #3 on: August 19, 2008, 04:08:14 PM »
Rob, I've been staring at a bike and thinking about this.  Don't you think having a shift lever hanging down between the two pegs might kinda get in the way and causing constant bruising of the ankles and lower shin?  ;)  It may be doable with some sort of fixture containing a specially angled shift lever bolted behind the rider peg.  Then a linkage rod could be fabricated and hooked into the primary shift lever.  I see why rear-sets cost so much now, never really put much thought into them before...
I plan on making a version of this shifter without the "heel" portion so would probably use something like that with a modified angle between the toe portion and where the selector rod attaches.
« Reply #4 on: August 19, 2008, 05:01:33 PM »
I think Rob just needs full rear sets.   :D
« Reply #5 on: August 19, 2008, 05:19:51 PM »
Then you have to ride all hunched over in town so you can shift and brake!  :o  I see the alure of a secondary shifter on the rear peg but also wonder if it might get in the way around town...
« Reply #6 on: August 19, 2008, 06:59:33 PM »
I think the dual shifter is not likely to see the light of day.  I wouldn't loose too much thought-time on it!
Rear-sets have been on my mind for decades, now, but I really like having a variety of places to put my feet.
