Author Topic: Fm Radio Reception  (Read 12505 times)
Online Bob_Roller
Re: Fm Radio Reception
« Reply #30 on: March 08, 2009, 08:41:32 AM »
50 miles with a 2.7kW FM station is a haul :)
Remember, the uglier the antenna, the better  :D
Well seeing as this thread was re-activated recently, the transmitter for this radio station was moved to about 35 miles north of the Tucson area.
Now it's 80 miles southeast of me, the antenna height is a little lower in elevation, but the power output was raised to 95kw , and there isn't a mountain range in between the station antenna and my antenna.
The change over of transmitters just happened this week, as I noticed an increase in signal strength on my reciever, and the quality of the signal has gotten a lot better.
wa1udg
« Reply #31 on: August 18, 2011, 01:31:28 PM »
If it stays up all winter it ain't big enough.  -.-. --.-  ..-. -.. -.. .
Darwin_R65
« Reply #32 on: August 19, 2011, 08:23:42 PM »
CQ FDDE
wa1udg
« Reply #33 on: September 02, 2011, 11:51:23 AM »
Here's some basic antenna stuff..FM broadcast is subject to mutipath, the same thing which caused "ghosting"  (multiple images) on the old analog TVs.  In FM stereo,  multipath causes stereo separation to degrade and introduces distortion.  The solution is a directive antenna, which "ignores" reflected"  AKA multipath signals  from the back and sides (technical term is "front to back and front to side ratio" ) and responds only to the signal  from station it is pointed directly toward.  They are big, 6 to 8 foot boom antennas , and require a rotator if  stations from different headings are desired  , but the rotator can be used to "fine tune" the direction for  the clearest signal.  Coaxial cable is a must, but can be run just about anywhere - underground if necessary.
Old ANALOG TV antennas can also work, the "FM" band was squeezed between Ch 6 and 7 on the old system  but remember, the new HD TV system is UHF (400MHZ and above) only, with some rare exceptions  and THOSE antennas do NOT respond  well to 87-108 MHZ FM broadcast, unless the maker added an element for FM.  Some do.
An old TV antenna can also make a pretty good directive scanner antenna when mounted with the elements pointed vertically. FM antennas used to be mounted  only with the elements parallel to the ground, when FM began to become popular in vehicles,   broadcasters switched to "circular" "polarization, which the veritcal AM whips  on vehicles  would respond to.  Should you install an outdoor FM antenna and find it not performing well in "horizontal mode" try turning it 90 degrees  most good "outdoor" FM antennas have two sets of holes on the boom to give you a choice.
« Last Edit: September 02, 2011, 01:53:13 PM by wa1udg »
wa1udg
« Reply #34 on: September 02, 2011, 01:45:37 PM »
If you mount an FM antenna in vertical fashion, i. e. elements  pointing up and down, use thickwall PVC pipe, metallic pipe can disrupt the proper function when it is on the same plane as the elements.
You can make a simple wire FM antenna by cutting 4.6 feet of wire, splitting it in the middle and connecting one length to the center of a coax line and the other to the braid, forming a "T"   The antenna will receive well broadside to the station and pick up very little when either end is pointed at it.  If you hang it up rotated 90 degrees with the top of the "T"  pointed up and down it wil receive equally well in all directions.  --... ...--  HS
Online Bob_Roller
« Reply #35 on: September 02, 2011, 02:39:52 PM »
With the installation of the 'common generic' television antenna in the attic over the garage, I've had no problem with reception since .
