Author Topic: Fm Radio Reception  (Read 12506 times)
Re: Fm Radio Reception
« Reply #15 on: February 07, 2008, 06:30:28 PM »
I use the antenna for all local HD stations.
« Reply #16 on: February 08, 2008, 06:59:33 PM »
I havn't tuned  into a local station since 1996, if it wasn't for cable, I don't know if I would even have a television !!
« Reply #17 on: March 03, 2008, 08:40:24 PM »
Thanks for the new streaming station to listen to here at work!  (Maybe in my new home, as well!)
Fascinating reading!  (I love radio)
http://www.azcentral.com/news/columns/articles/1129ruelas29.html
« Reply #18 on: March 04, 2008, 12:43:18 PM »
I've been interested in radio, since I first got a mutliband portable radio from Radio Shack, back in the mid 1960's.
It seemed amazing to pick up AM radio stations from far away places, like Des Moines, Iowa, St Louis, Missouri, Indianapolis, Indiana and on occasion Denver, Colorado.
I had that radio up until I left Iran in 1979, it got lost in shipping somewhere trying to get back to Chicago.
I would tune into the Voice of America at night, to get the current US news, as the local news outlets in Esfahan,Iran, had no international news to speak of.
My brother was a ham radio operator in high school and college, and during the month of June, there was a US Civil Defense operation called 'Field Day', the purpose was to have a communications network in place, in case of a 'national emergency' which I took as a nuclear war.
The objective was to contact as many other ham radio operators in a 24 hour period, and document the contact.
The site was to be self sufficient, not connected to the local power grid, so generators and the like had to be set-up
It was kind of ironic, that the site that this group of my brothers fellow ham radio operators had chosen, was the final resting place for the world's first nuclear reactor.
Out in the southwestern suburbs of Chicago, the first site of the Argonne National Laboratory complex, which is now part of the Cook County, Illinois forest preserve district.
For you gps fanatics, the co-ordinates are :  41 degrees 42 minutes 08 seconds N,  87 degrees 54 minutes 48 seconds W.
« Last Edit: March 04, 2008, 06:40:53 PM by Bob_Roller »
« Reply #19 on: March 04, 2008, 07:41:50 PM »
My last two years of high school, I was in a Boy Scout Explorer Post that specialized in radio broadcasting.  We were sponsered by the American Forces Radio & Television Services, which had classrooms at Fort Harrison, here in Indianapolis.  We got to play disc jockey and learned to use the hardware and even had teletype feeds.  AFRTS also pressed their own vinyl.  They would select cuts from 'regular' records, and combine them onto their own.  The quality was not up to retail standards, but it was very interesting.
blacksmith
« Reply #20 on: March 08, 2008, 10:34:32 PM »
I wonder if you are getting interference from some other device in your house?
Signal level stays, but quality suffers is indication of interference.
Do you have another radio to try in case yours has developed a problem?
One day it works fine , next it has problems: Did you bump the tuner, becoming slightly off frequency may cause such a issue.
Do you have a local/ distance switch that may have been bumped on/off?
Check you antenna connections.
I work at a R&D lab here in Iowa designing making radios/antennas for military and cellular companies.
I have a question for anyone out there that may have some radio experience.
The FM radio station that I listen to is a low power station about 35 miles away, I get great recption in the cage, but the home tuner isn't quite so happy.
I have used two 30 foot lenghts of small gauge wire as an antenna, and up to a week ago it worked great.
But now I am having recption problems , the indication on the tuner shows the same signal strength, but the quality of the signal is at best poor.
My thought was to install a TV antenna in the attic, run coax to the tuner, then run the coax into a splitter, then to the antenna terminals on the back of the tuner.
I would prefer to mount the antenna outside with a rotator, but the home owners association doesn't allow any antennas to be mounted on the roof of the building.
I have a single level home, and at best the antenna would be 20 feet off of the ground.
Ant thoughts , on whether this may help my reception problem ?
« Reply #21 on: March 10, 2008, 07:59:02 PM »
Since I connected the 'TV' antenna to coax, all of my problems have disappeared.
This radio station is located in a quite remote area about 50 miles from me, as the crow flies, and there is a line of 'mountains' (The Superstition Mountains, of the Lost Dutchman's Goldmine fame) about the same height as the transmitter antenna between the transmitter and my location, so it isn't an ideal line of sight situation.
The station has a lot of 'technical ' difficulties, 'dead' carrier signal is quite common.
blacksmith
« Reply #22 on: March 10, 2008, 08:37:45 PM »
Ok, Great!
Your back in the saddle.
Now for a more advanced problem.
How does Jack in Iowa get your warm weather and radio signals?
Ya Ya!  I know.
Why the beejeebers am I living Iowa anyway.
More time to work on motorcycles and less time to ride them.
It's a ballance in life I have learned to live with until I retire.
jack
« Reply #23 on: March 10, 2008, 08:53:59 PM »
Getting the weather to you is going to be a problem !
I lived in the Chicago area for 37 years, WINTER is the reason I now reside in the Phoenix area, I had the opportunity to escape the midwest, courtesy of losing my job, best thing that ever happened to me!
But come out here in June, when it's 115 F. in the shade, and asphalt is 180 F., and see what you think of 'warm' weather then !
You can listen to this radio station on-line, when they don't have 'technical' difficulties with the streaming broadcast.
« Reply #24 on: March 20, 2008, 06:26:12 PM »
Got the antenna installed in the attic, and all of the coax run and hooked up to the reciever.
Didn't get it done too soon, it was 104 F. in the attic this afternoon at 3 pm.
« Reply #25 on: March 20, 2008, 06:54:24 PM »
Cool!  (well, warm!)
I am considering an external antenna as a money-saving alternative to the cable "package".
My next step is to read up on digital and the government's plan to put a "black box" in every cheapskates home, next year... >:(
Cable TV reception would be nice, and internet is my primary draw, but the "cheap" package is $99/month (for the 1st year...) and includes a phone - which I don't need, but would be paying for, anyway.
I am sure if I tried to buy just the TV and the internet, it would be more money.
I have a dream of having 12 $100 bills in my closet at the end of the year, instead. ;)
« Reply #26 on: March 07, 2009, 12:20:31 AM »
No hundred dollar bills in the closet, yet...  :-[
Darwin_R65
« Reply #27 on: March 07, 2009, 02:51:26 AM »
Not the closet, you gotta look in the garden and apply plenty of fertilizer
 :D
John
JimJ
« Reply #28 on: March 07, 2009, 08:29:42 PM »
50 miles with a 2.7kW FM station is a haul :)
Remember, the uglier the antenna, the better  :D
« Last Edit: March 07, 2009, 08:30:32 PM by JimJ »
« Reply #29 on: March 07, 2009, 10:19:56 PM »
 :D
John
If the gubamint doesn't want you growing cannabis, you know that this plant will be illegal!!!   :)
