Author Topic: I have a new (old) blower!!!!!  (Read 2469 times)
« on: November 20, 2010, 09:07:05 AM »
I installed new heat and air in the house yesterday to replace a working but 25 year old system.  When they pulled out the old furnace/AC blower I took one look and saved it from the waist bin.
I have always needed a blower for doing tuneups and this one is industrial!  One motor with two blowers - one on each end of the motor.
So I need to hook it up.  There are six wires two brown that are connected to a capacitor (not a problem) and a red, white, black and blue.
I think the white is ground and the other three are the phases.  How do I connect these to a switch to get house power to them and run the fan.  Can I get varible speed by energizing less than three phases?
Thanks in advance.   :D
Re: I have a new (old) blower!!!!!
« Reply #1 on: November 20, 2010, 09:19:37 AM »
You'll probably need 220v service, if you don't have an outlet for this, say for an electric clothes dryer, you may not be able to do this, unless you run a dedicated circuit from the circuit breaker box .
Check to see if there is a data plate on the electric motor, it should be on there .
« Last Edit: November 20, 2010, 09:20:56 AM by Bob_Roller »
« Reply #2 on: November 20, 2010, 09:35:34 AM »
An excellent refuse/reuse/recycle idea for the blower unit, but the 220V requirements will likely create more revamp problems than it's worth.
If memory serves, Harbor Freight sells a 110V blower that looks just like the ones used by NASCAR teams over at your local track. They do move a lot of air and are probably lighter and easier to store away.
Darwin_R65
« Reply #3 on: November 21, 2010, 04:33:01 AM »
color coding of wiring depends on where in the world you live.
check this web page for an explanation.
http://www.3phasepower.org/3phasewiring.htm
« Reply #4 on: November 21, 2010, 03:45:32 PM »
It does sound like a 3 phase motor which is not something you find in domestic properties in the UK.
If it is and you have a 3 phase supply it doesn't matter which way around the 3 phase wires are connected. All that will happen is that the motor will rotate in one direction or the other.  If it's the wrong direction just swap 2 of the phase wires and it will reverse the direction for you.
Just a thought though single phase motors have a capacitor to provide some phase shift during starting - 3 phase motors do not usually need one so I think what you have is a 3 phase motor being operated on a single phase supply. See this link for connections and how this works:
http://www.gwm4-3phase.com/uands/static1.htm
Not normally the power output will be substantially lower and the motor will tend to overheat.
« Last Edit: November 21, 2010, 04:09:23 PM by bhodgson »
