Author Topic: Hello, I'm new :)  (Read 2185 times)
Offline Scottie
Hello, I'm new :)
« on: October 08, 2018, 01:29:45 PM »
Greetings everybody.
I'm Scottie, I live in St. Louis Missouri and just bought a beautiful 1979 R65. I used to ride dirt bikes as a kid but haven't been on a bike in 30+ years figured if I was going to do it I needed to do it soon. It was the right choice and every minute I spend on it is therapeutic. It's in great shape but figured I better come up to speed on it if I want to keep it that way so hear I am. Hope the pic uploads and displays okay.
Offline wilcom
Re: Hello, I'm new :)
« Reply #1 on: October 08, 2018, 01:52:22 PM »
Scottie...……..
Very nice example, nice find and welcome
1982 BMW R65LS
1972 R75
1964 R50/2
19xx R27
ZX-11
« Reply #2 on: October 08, 2018, 04:19:35 PM »
A lovely bike, however, like most R65s it does nee a centre stand refurb.
Offline Adrian
  • The Old Hairy Biker Sez...
« Reply #3 on: October 08, 2018, 08:00:20 PM »
Welcome - nice looking bike [ch128077][ch128521]
1984 R65 (860)
« Reply #4 on: October 09, 2018, 05:19:26 PM »
Welcome.
The natives are (mostly) friendly.
However, if your R65 has an amber LED at approximately the 7,500rpm mark on your tacho - don't mention it!
« Reply #5 on: October 09, 2018, 07:27:41 PM »
Very nice looking 1st gen r65!
« Reply #6 on: October 13, 2018, 06:01:25 PM »
Welcome..... very nice I have a 79 in the same colour.
I still dont understand why the 70 US spec was single disc ?  wonder how effective the brakes are compaired to the UK/Euro twin disc. There is an owners manual for it in the tech section if you havent got one.
Lou …. don't mention the rev light (mine works lol)
« Last Edit: October 13, 2018, 06:03:45 PM by Lucky_Lou »
« Reply #7 on: October 13, 2018, 08:54:54 PM »
Lou, the standard configuration for all single single shock R65s (except LS) sod in Australia was single disc.
The wife's became a twin ATE when a friend was going to Germany and was tasked to buy the accessory kit from BMW to fit a 2nd disc. I have always regarded her R65 (R65/80) as being "adequately" braked in both single and dual disc lives, in fact if I had an option at all I would probably have said of the twin disc arrangement "good brakes, but wooden".
I have never really felt concerned about the single disc that was fitted to my 1984 R65, again my thinking was that it was not the best brake in the business (especially compared to the GSA), but that it supplied adequate braking.
I should fess up here that my R65 had a very long lever due to an absurdly long brake hose that I had to loop over the rear of the headlight - the long lever beign the result of air trapped in it that I never bothered to eliminate  as I was always going to fit a better hose just as soon as I go a round to-it.
Then in the last few weeks I fitted a K100RS front end to the the R65 and the collateral damage to that was twin Brembo calipers (I also own a set of Brembo 4-spots but couldn't justify the cost of the inevitable new master cylinder).
Well, the combination of HEL stainless lines and retaining the 12mm master cylinder has opened previously undreamed of levels of braking power.
On a recent ride I amused the members of my club by performing "stoppies" on a particularly sticky stretch of bitumen, there are photos of the back wheel nearly three feet off the ground. I abandoned that fun and games as I started thinking about the unfair strains on head stem bearings, frame and the general wear and tear of the rear wheel slamming back down onto the ground. But the point was that the R65 is now almost absurdly over-braked, I can easily lock the front wheel with a single finger curled around the lever. It's not dangerous in my view, nut it is something that will take a while to adjust to.
I didn't bother to measure the piston size int he ex-K100 calipers, they pressed home without any great pressure and expelled fairly clean fluid, so I decided to simply use them as-is and see how they go. I do not think that whatever the hydraulic ratio is that I've ended up with would have worked with "rubber" hoses, only the unyielding nature of braided steel lets it work.
Offline jackwalls
« Reply #8 on: October 24, 2018, 12:52:02 PM »
Hello Scottie new myself and your bike looks great but how did you manage to get the photo posted, every time i try says file to big !
« Reply #9 on: October 24, 2018, 08:04:57 PM »
I have limited attachment size to 1 MB, you will need to resize as you were trying to post pics that were almost 1.5 MB.
