Anyone got any tips on changing your own tyes?
Here's a link to a DIY ghetto-style bead breaker for motorcycles.
http://www.webbikeworld.com/t2/bead-breaker/motorcycle-tire-bead-breaker.htm I've gotta take my bride's car to be inspected right now but I'll post today my learned tricks on swapping tires on my snowflake R65. Be back shortly... Hang on. It ain't no biggie.
OK, I'm back. Car passed emissions test and it sure ought to... Recently paid $638.00, just for the cat-not labor, for a rebuilt catalytic converter due to the failure of some attached electronics. Grrr. Extended warranty did not cover because exhaust systems are considered 'disposables' just like tires and wiper blades. Double grrr...
So, to your tire changing exercise. I recently removed the rock hard vintage Metzlers from my R65s
snowflake rims. As to the rims being easily damaged, that would be from the changer's experience level, tools used, precautions taken, and deficits in his gene pool.
If you wish, you can make your own rim guards. Buy some large i.d. vinyl tubing -maybe around 0.75 inch- slit a piece about four inches long and you've got a rim guard! Make a few. Also suggest you grow a third hand so it'll be easier to fit them as you use your remaining two hands to work the tire spoons.
Two motorcycle tire spoons are needed. Three's better. WD40 is a good tire lube because it will eventually evaporate. Soapy water might lead to corrosion issues inside the wheel rim.
You will want to lay the tire across a couple 2x4s while you work on it. Must protect the brake disc from side loads and damage.
After that, it's a matter of getting the tire bead into the deepest part of the rim and then inserting a spoon across from the collapsed bead. Get one side off, remove the inner tube -if you're running them- and then pry off the second bead.
My narrower front tire was a booger to get off so I was not loking forward to the rear. Guess the wider rim helped because the rear came off "piece of cake". You may wish to begin with the rear tire removal to pick up some new skills before tackling the front.
Prepare to get dirty. Have plenty of work space so that when a spoon slips and cracks you across your knuckles, you'll have lottsa room to jump around. Someday, ask me how I learned this tip years ago.
No screwdrivers, at all, none, never! Want rim damage? That's how it happens. If we can simply save just one more snowflake...
Do it yourself and learn some new skills. You'll save some money and impress those who know you. 8-)
