Author Topic: Swapping out different wheels?  (Read 897 times)
Spicy_McHaggis
« on: June 29, 2008, 11:01:21 PM »
I tried searching the forums but came up empty on this one.
I'm wondering - what different wheels will work with little to no modifications needed, on an '84 and an '82 R65...does anyone know?
I cannot find a good dualsport FRONT tire for an 18" wheel...so am considering a conversion to a larger size (anything larger than 18"!!!).
Can it be done, and if so, what do I need to start looking for?  Or, is this one of those "well, you need this...and this...and this...and...." type of projects?
Thanks!
Spicy
Re: Swapping out different wheels?
« Reply #1 on: June 30, 2008, 05:47:53 AM »
Spicy,
I am running a set of wire wheels from a R80 ST.  The front is a 19 inch jobby.
For the rear you can use any twin shock wire wheel from R60/75/80/90/100 etc.
But the front is quite special as you need the less wide 3 rib front hub from the ST or GS to fit in the R65 forks.
Once sourced it is a direct swap.
Steve H
PS - you will need to lift the fork stantions up by half an inch to offset the larger wheel, otherwise she'll handle like something from Orange County!
« Last Edit: June 30, 2008, 05:49:38 AM by steve_hawkins »
Spicy_McHaggis
« Reply #2 on: June 30, 2008, 10:00:24 AM »
Cool, thanks Steve!!!
« Reply #3 on: June 30, 2008, 01:52:39 PM »
Or, can he buy the 18" rear and put it on the front?  Are you still looking at those Kendas, Spicy?
Spicy_McHaggis
« Reply #4 on: June 30, 2008, 03:44:44 PM »
Yeah, still looking but haven't bought 'em yet.  I'm having a hard time finding someone that won't charge 70 bucks to ship them up here...
