Author Topic: Ignition coil part number?  (Read 765 times)
Offline beemer
  • The Red Tomato!!!
« on: June 21, 2008, 08:05:24 PM »
Can someone tell me the spec on a Bosch ignition coils,taken from a K100,are these all 12v? the number on the coils are-: 0.221 500 202. i'm not sure if some of these were 6v? thanks.
airhead
Re: Ignition coil part number?
« Reply #1 on: June 21, 2008, 08:26:02 PM »
You did say K100??
The BMW part number is 12 13 1 459 513.
If you are thinking it will replace an R dual O/P coil you may be unable to, though I must admit I've never contemplated it or heard of it being done.
The K coil is indeed a dual O/P coil, 2 being required for the K100 with one feeding 1 and 4 cylinders, the other 2 and 3. They are powered from the computer so are supplied 12v to the primary. The actual resistance of the primary may not be compatible with the ignition control unit of the R.
Bill..........................;-)
Offline beemer
  • The Red Tomato!!!
« Reply #2 on: June 22, 2008, 04:18:23 AM »
You did say K100??
The bosch part number is as above but i can't get any info on it,anymore help on this?.
