Author Topic: DIY Battery Cable  (Read 1131 times)
DIY Battery Cable
« on: June 18, 2008, 06:20:30 PM »
I'm a big believer in electrical ground wires. My 1981 R65 carries the OE negative battery cable. It looks it, too. OK, another project.
Solid copper lugs for #4-6 cable with .187" holes were $2.99 at the 'Zone. A pre-made #4 battery cable with copper wire ran me $3.99 and I'm out the door.
Back in the shop, first order of business is to cut off the stamped steel terminal lug and swage on a new copper lug. Smooth off some sharp edges, couple layers of shrink tubing and we can test fit to the upper battery terminal.
Run the loose end down to the ground location near the speedometer drive and mark it for length. Finish the cable as the other end. Bolt that rascal up.
Tested the old cable on the DVOM and found a little bit of resistance. My eight buck cable compares to BMWs asking price of $28.33.
The original cable is a metric size that specs out to 5 gauge. You're not likely going to find that wire size at NAPA! Step up to 4 ga - it's a bit heavier and a tad more difficult to shape - rather than the smaller 6 ga. It's worth the effort.
Here's my aircraft cable swaging tool at work. Stone axe simple and FAA approved. The swaging tool is available through Aircraft Spruce and Supply, Wicks Aircraft and several other sources.
Finished cable with two layers of shrink tubing. This end is ready to install.
Re: DIY Battery Cable
« Reply #1 on: June 18, 2008, 06:24:52 PM »
Cool!
Now make one long enough to route to the lower-right side transmission/engine bolt, and eliminate having to loosen the transmission vent screw every time you want to disconnect the battery (like to remove the front cover).
« Reply #2 on: June 18, 2008, 06:35:52 PM »
Cool! Now make one long enough to route to the lower-right side transmission/engine bolt, and eliminate having to loosen the transmission vent screw every time you want to disconnect the battery (like to remove the front cover).
Dang! That's a good idea... Add this back on the list.
« Reply #3 on: June 18, 2008, 06:45:06 PM »
But I had never seen one of those swagging tools before.  I am going to have to get one!  Thanks for the nice pictures!
« Reply #4 on: June 18, 2008, 07:49:58 PM »
http://www.aircraftspruce.com/
http://www.wicksaircraft.com/
http://www.yardstore.com/search.htm  $9.95 here. Lowest price I've ever seen. I paid 40 back in the day. Search for swaging tool.
Jon_P
« Reply #5 on: June 19, 2008, 12:22:30 PM »
funny you should say stone axe simple, i have a cable crimper that we use on the big trucks that you hit with a hammer to crimp it, i got it from one of the "just as bad as a dope dealer" tool truck guys for around $15 or so. everytime i use it i feel the knuckle dragger in me come out.
great idea rob, must ass that to the list of things to do when i have to replace or remove.
